> Steering column movement - advice please !?!
MM1
post Nov 30 2020, 02:26 PM
914 obsession continues
My '73 steering column moves in every direction, but last night I noticed that it doesn't seem/feel like the upper bearing. What do I know, though.
If the entire column moves like this (icloud link below), is it necessarily the lower bearing, or could it be something else?
Obviously, this is my first time into the column, and man, is this gonna be a learning experience - (indicator switch needed replacement, will replace ignition switch and clean tumbler).
https://share.icloud.com/photos/0xOTITlUBsUJtbldsiNxBtOYw
MM1
post Nov 30 2020, 02:43 PM
Thank you, Aaron, appreciate the advice - I'll check that (my neck is hurting just thinking about it)!
Btw - just for clarity, Mark recently posted that the crush sleeve pictured on my column does do with the metal inner bearing type: "Metal center bushing for VW 111 953 559A is 111 953 535D"
Hope I got that correct, Mark.
To you both, I say: (IMG:style_emoticons/default/pray.gif)
- Lo-Fi Version Time is now: 29th April 2026 - 03:57 AM
