| MM1 |
Nov 30 2020, 02:26 PM
914 obsession continues ![]() ![]() ![]() Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California
My '73 steering column moves in every direction, but last night I noticed that it doesn't seem/feel like the upper bearing. What do I know, though.
If the entire column moves like this (icloud link below), is it necessarily the lower bearing, or could it be something else? Obviously, this is my first time into the column, and man, is this gonna be a learning experience - (indicator switch needed replacement, will replace ignition switch and clean tumbler). https://share.icloud.com/photos/0xOTITlUBsUJtbldsiNxBtOYw |
| 914Sixer |
Nov 30 2020, 02:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,470 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
That is the factory metal bushing used for 72-73. Yes it is similar to the shift crush sleeve not nowhere the same size. You need to check the "U" joint behind steering column Your steering rack could have a torn rubber bushing too.
| MM1 |
Nov 30 2020, 02:54 PM
That is the factory metal bushing used for 72-73. Yes it is similar to the shift crush sleeve not nowhere the same size. You need to check the "U" joint behind steering column Your steering rack could have a torn rubber bushing too. Thank you, Mark - I'll check that, but as I just need to get mine driving first (Feb-March?), if it is the rubber bushing, I'll have to pull the rack out and address it then, since my tie-rod boots are split too . . .guess that means turbo-tie rod kit from Pelican . . . |
MM1 Steering column movement - advice please !?! Nov 30 2020, 02:26 PM
double-a
My '73 steering column moves in every directi... Nov 30 2020, 02:35 PM
double-a
That is the factory metal bushing used for 72-73.... Nov 30 2020, 02:46 PM
double-a
That is the factory metal bushing used for 72-73... Nov 30 2020, 02:57 PM
MM1
[quote name='MM1' post='2870718' date='Nov 30 202... Nov 30 2020, 04:31 PM
double-a
[quote name='MM1' post='2870718' date='Nov 30 20... Nov 30 2020, 04:34 PM
MM1
[quote name='MM1' post='2870750' date='Nov 30 202... Nov 30 2020, 04:38 PM
MM1 Thank you, Aaron, appreciate the advice - I'll... Nov 30 2020, 02:43 PM
aharder If your going to Turbo Tie Rods, you might conside... Nov 30 2020, 06:37 PM
rhodyguy The front end/steering work can be a slippery slop... Nov 30 2020, 06:51 PM
horizontally-opposed
The front end/steering work can be a slippery slo... Nov 30 2020, 08:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 03:57 AM |
