> Steering column movement - advice please !?!
MM1
post Nov 30 2020, 02:26 PM
914 obsession continues
My '73 steering column moves in every direction, but last night I noticed that it doesn't seem/feel like the upper bearing. What do I know, though.
If the entire column moves like this (icloud link below), is it necessarily the lower bearing, or could it be something else?
Obviously, this is my first time into the column, and man, is this gonna be a learning experience - (indicator switch needed replacement, will replace ignition switch and clean tumbler).
https://share.icloud.com/photos/0xOTITlUBsUJtbldsiNxBtOYw
914Sixer
post Nov 30 2020, 02:41 PM
That is the factory metal bushing used for 72-73. Yes it is similar to the shift crush sleeve not nowhere the same size. You need to check the "U" joint behind steering column Your steering rack could have a torn rubber bushing too.
MM1
post Nov 30 2020, 02:54 PM
QUOTE(914Sixer @ Nov 30 2020, 03:41 PM) *
Thank you, Mark - I'll check that, but as I just need to get mine driving first (Feb-March?), if it is the rubber bushing, I'll have to pull the rack out and address it then, since my tie-rod boots are split too . . .guess that means turbo-tie rod kit from Pelican . . .
double-a
post Nov 30 2020, 02:57 PM
QUOTE(MM1 @ Nov 30 2020, 12:54 PM) *
you will NOT regret the money spent on a turbo tie rod kit!
- Lo-Fi Version Time is now: 29th April 2026 - 03:56 AM
