| Nacho |
Nov 30 2020, 07:02 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None
Happy post Thanksgiving everyone.
Im in the middle of installing new windows seals from 914Rubber and it seems most seals are larger that what they need to be. This is good as most 914 are not exactly the same. In the below picture am I supposed to cut the section of the vertical seal that goes beyond the aluminum retaining strip? Does my seal look installed in the correct orientation? |
| Mikey914 |
Dec 1 2020, 10:35 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,785 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
PS yes your seal appears to be installed correctly.
Nacho Window Seal Vertical install Nov 30 2020, 07:02 PM
Nacho @mikey914 Can you give me some guidance?
Thanks Dec 1 2020, 09:25 AM
mb911 I had to trim mine down.. Dec 1 2020, 09:35 AM
Nacho
Did you cut to the wh... Dec 1 2020, 09:58 AM
mb911 Left it a bit long for shrinking Dec 1 2020, 09:58 AM
Mikey914 Thanks for asking, Yes we make them longer to you ... Dec 1 2020, 10:34 AM
Nacho
PS yes your seal appears to be installed correctl... Dec 1 2020, 11:42 AM
rhodyguy If you pulled them thru the strip give them time t... Dec 1 2020, 12:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 09:04 AM |
