| Nacho |
Nov 30 2020, 07:02 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None
Happy post Thanksgiving everyone.
Im in the middle of installing new windows seals from 914Rubber and it seems most seals are larger that what they need to be. This is good as most 914 are not exactly the same. In the below picture am I supposed to cut the section of the vertical seal that goes beyond the aluminum retaining strip? Does my seal look installed in the correct orientation? |
| rhodyguy |
Dec 1 2020, 12:59 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you pulled them thru the strip give them time to recover before cutting. Glycerin is a super lube for rubber items. For outer window scrapers, trim to fit after recovery and the end caps are put back on.
Nacho Window Seal Vertical install Nov 30 2020, 07:02 PM
Nacho @mikey914 Can you give me some guidance?
Thanks Dec 1 2020, 09:25 AM
mb911 I had to trim mine down.. Dec 1 2020, 09:35 AM
Nacho
Did you cut to the wh... Dec 1 2020, 09:58 AM
mb911 Left it a bit long for shrinking Dec 1 2020, 09:58 AM
Mikey914 Thanks for asking, Yes we make them longer to you ... Dec 1 2020, 10:34 AM
Mikey914 PS yes your seal appears to be installed correctly... Dec 1 2020, 10:35 AM
Nacho
PS yes your seal appears to be installed correctl... Dec 1 2020, 11:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 09:06 AM |
