| GGerg1186 |
Dec 7 2020, 09:10 PM
Newbie ![]() Group: Members Posts: 15 Joined: 28-September 20 From: Dubuque IA Member No.: 24,724 Region Association: Upper MidWest |
Does anyone have general dimensions for max distance between the outer CV faces at zero, plus twelve, minus twelve degree angles?
I read that the stock 914 CV's are basically the same as a VW type 1, and on blind chicken racing the max angle is 12 degrees. ![]() I have to build custom trailing arms for my sandrail project and need to develop the 3D suspension travel geometry that ensures I do not exceed the CV capacity throughout the range of motion. ![]() If I have to I will just physically measure the parts, but it would be helpful if anyone who has already found this information could share. Yes, I am aware the 3D geometry along with camber, toe, etc needs to be calculated, but these general dimensions will get me 99% of the way there. Thanks |
| Mike Bellis |
Dec 10 2020, 08:49 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Swap over to 930 CV's or you are asking for trouble. You may also want to go non-plunging with sliding axles.
https://www.pacificcustoms.com/axles.html https://www.rcvperformance.com/ultimate-930...-28-spline.html |
GGerg1186 Stock 914 CV Geometry Dec 7 2020, 09:10 PM
Bleyseng I think guys are using 930cv’s for more angle an... Dec 9 2020, 01:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 09:11 PM |
