> Weber mixture screws
dumbjim
post Dec 21 2020, 09:27 AM
Hi all, I spent yesterday fooling around with my weber idf 40's. by following mrbubbleheads instructions. With my snail, I got all four barrels pulling the same by adjusting the air bleed screws. I then moved on to the mixture screw. The mixture screws have absolutely no effect on how the engine is running. I can back them out or screw them in and there's not change in the idle. Is there something else going on here? In general, after adjusting the bleed screws, the engine is running pretty smooth. Any ideas? Thanks for reading.
rhodyguy
post Dec 21 2020, 10:47 AM
How much are the ABS backed out? CB book on pre-run setup states "Set them 1/2 turn off the bottom". So, reset. Set the idle speed screws achieving .004 clearance between the leading/forward butterfly and Venturi. Then the idle mix screws at 3 turns out from gently seated. This will more than likely result in a high idle. Don't trust your linkage. Back the pass side idle speed screw just off the stop. Now measure flow. Adj linkage as nessassary.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:49 AM
