| dumbjim |
Dec 21 2020, 09:27 AM
Newbie ![]() Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
Hi all, I spent yesterday fooling around with my weber idf 40's. by following mrbubbleheads instructions. With my snail, I got all four barrels pulling the same by adjusting the air bleed screws. I then moved on to the mixture screw. The mixture screws have absolutely no effect on how the engine is running. I can back them out or screw them in and there's not change in the idle. Is there something else going on here? In general, after adjusting the bleed screws, the engine is running pretty smooth. Any ideas? Thanks for reading.
| rfinegan |
Dec 21 2020, 10:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
sounds like your idle speed is high and off the mixture circuits. Reduce the speed and try the screws again
| dumbjim |
Dec 21 2020, 06:45 PM
| Charles Freeborn |
Dec 22 2020, 12:29 AM
Member ![]() ![]() Group: Members Posts: 321 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
dumbjim Weber mixture screws Dec 21 2020, 09:27 AM
johnhora Have these been rebuilt recently? Dec 21 2020, 10:06 AM
Ansbacher Take it to a proper mechanic. This is above your p... Dec 22 2020, 01:07 PM
rhodyguy How much are the ABS backed out? CB book on pre-ru... Dec 21 2020, 10:47 AM
Ansbacher Be careful adjusting those air bleeds to get the b... Dec 21 2020, 12:45 PM
Charles Freeborn There are a LOT of factors in proper jetting, sync... Dec 21 2020, 02:19 PM
914043 I don't know if the 40 idf weber are set up th... Dec 21 2020, 09:36 PM
rhodyguy I don't get the 800rpm idle thing at all. Dec 22 2020, 07:34 AM
dumbjim Thanks for your comment Ansbacher. How am I gonna ... Dec 22 2020, 07:43 PM
Charles Freeborn
Thanks for your comment Ansbacher. How am I gonna... Dec 23 2020, 11:22 PM
IronHillRestorations I’m thinking @914043 could be on the right tra... Dec 24 2020, 07:21 AM
rhodyguy One has a jam nut and one doesn't. How could t... Dec 25 2020, 09:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:04 AM |
