> Weber mixture screws
dumbjim
post Dec 21 2020, 09:27 AM
Hi all, I spent yesterday fooling around with my weber idf 40's. by following mrbubbleheads instructions. With my snail, I got all four barrels pulling the same by adjusting the air bleed screws. I then moved on to the mixture screw. The mixture screws have absolutely no effect on how the engine is running. I can back them out or screw them in and there's not change in the idle. Is there something else going on here? In general, after adjusting the bleed screws, the engine is running pretty smooth. Any ideas? Thanks for reading.
rfinegan
post Dec 21 2020, 10:15 AM
sounds like your idle speed is high and off the mixture circuits. Reduce the speed and try the screws again
dumbjim
post Dec 21 2020, 06:45 PM
QUOTE(rfinegan @ Dec 21 2020, 08:15 AM) *
I had the idle at 800 rpm
Charles Freeborn
post Dec 22 2020, 12:29 AM
QUOTE(dumbjim @ Dec 21 2020, 04:45 PM) *
Take it to a proper mechanic. This is above your pay grade.
Ansbacher
post Dec 22 2020, 01:07 PM
[/quote]
Bad advice!!! You will never learn anything and in all probability it will not be fixed correctly anyway. Dig in, scour this site and the rest of the internet and you will find you can do this stuff yourself. It doesn't take a Werner von Braun rocket scientist.
Ansbacher
- Lo-Fi Version Time is now: 2nd April 2026 - 11:41 AM
