| pcdarks |
Dec 23 2020, 05:41 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
After many responses to converting to carburetion I've decided to look into cleaning up and using the stock system. My concern is the boots that go over the fuel injectors are ripped off and the main harness outer housing has turned so brittle that It will probably break if moved very much. I assume I will be changing all of the fuel and air hoses but the are a few connections that are proprietary that look like they are in bad shape. Where would I go for replacements. If I'm going to do this I'm going to do it clean. Thanks.
| tvdinnerbythepool |
Dec 24 2020, 07:22 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest
That rebuild connector kit is awesome! Man I wish I knew this was around and I could have made my own harness! (IMG:style_emoticons/default/welder.gif)
Is that new @mikey914 ?! (IMG:style_emoticons/default/beerchug.gif) |
pcdarks Cleaning up the stock fuel injection. Dec 23 2020, 05:41 PM
Rob-O You’d go to Jeff Bowlsby and buy a new harness. ... Dec 23 2020, 05:50 PM
porschetub
You’d go to Jeff Bowlsby and buy a new harness.... Dec 24 2020, 02:13 PM
FlacaProductions 914Rubber.com is your friend
Here's a link to ... Dec 23 2020, 05:54 PM
mepstein Jeff reuses your old connectors. 914rubber and res... Dec 23 2020, 07:28 PM
JeffBowlsby
Jeff reuses your old connectors. 914rubber and re... Dec 24 2020, 10:31 AM
Montreal914 And this place sells the connectors... Might be ot... Dec 23 2020, 07:46 PM
JamesM
And this place sells the connectors... Might be o... Dec 24 2020, 01:06 PM
JamesM
[quote name='Montreal914' post='2877557' date='De... Dec 24 2020, 01:09 PM
rhodyguy How much of the FI system don't you have? Dec 23 2020, 10:16 PM
pcdarks
i... Dec 23 2020, 10:21 PM
914werke :agree: :headbanger: :headbanger: :headbanger: Dec 24 2020, 10:35 AM
mepstein “FWIW the plastic connectors are of the same mat... Dec 24 2020, 10:57 AM
Mikey914
“FWIW the plastic connectors are of the same ma... Dec 24 2020, 03:21 PM
913B Great resource materials, just bookmarked. Dec 24 2020, 01:40 PM
JamesM
After many responses to converting to carburetion... Dec 24 2020, 01:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
