| HalfMoon |
Dec 23 2020, 07:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley?
Obviously the housing would have to be modified that much goes without saying. My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift). Direct experience with this modification very much sought. |
| bdstone914 |
Dec 23 2020, 11:08 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley? Obviously the housing would have to be modified that much goes without saying. My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift). Direct experience with this modification very much sought. @HalfMoon A later 911 clutch arm in the pedal may be adaptable to accomplish that. It has a taller arm but requires more offset to not interfere with the accelerator cable. Attached thumbnail(s) |
| HalfMoon |
Dec 24 2020, 08:35 AM
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley? Obviously the housing would have to be modified that much goes without saying. My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift). Direct experience with this modification very much sought. @HalfMoon A later 911 clutch arm in the pedal may be adaptable to accomplish that. It has a taller arm but requires more offset to not interfere with the accelerator cable. Interesting idea! Thanks for that. |
HalfMoon Increasing clutch cable transaxle pulley diameter Dec 23 2020, 07:55 PM
914e
Has anyone ever experimented with increasing the ... Dec 23 2020, 08:15 PM
windforfun Why bother? Get a life. Dec 23 2020, 08:17 PM
HalfMoon
Hey chum, what's y... Dec 23 2020, 10:04 PM
porschetub
You have got that backw... Dec 23 2020, 11:15 PM
BillC The clutch cable pulley doesn't do anything ex... Dec 23 2020, 08:17 PM
GregAmy All of the above. That's not how a pulley work... Dec 23 2020, 08:36 PM
Spoke
Or convert to hydraulic.
If you want to clean u... Dec 24 2020, 01:06 PM
Charles Freeborn
[quote name='HalfMoon' post='2877563' date='Dec 2... Dec 23 2020, 11:26 PM
HalfMoon
[quote name='HalfMoon' post='2877563' date='Dec ... Dec 24 2020, 08:34 AM
914Sixer Something else to ponder from Tangerine Racing Dec 24 2020, 09:11 AM
HalfMoon
... Dec 24 2020, 09:56 AM
gereed75 It is possible to change the pull ratio at the pul... Dec 24 2020, 09:14 AM
HalfMoon
It is possible to change the pull ratio at the pu... Dec 24 2020, 09:57 AM
old914dog
It is possible to change the pull ratio at the p... Dec 24 2020, 10:46 AM
stownsen914
It is possible to change the pull ratio at the pu... Dec 26 2020, 07:08 AM
Chris914n6 Change your technique slowfoot :poke:
*nothing... Dec 24 2020, 04:06 PM
wattele I was thingking about converting to hydraulic.
My ... Dec 25 2020, 11:47 AM
Mark Henry
My... Dec 26 2020, 09:55 AM
Mikey914 Hey guys , just a thought. You are effectively sho... Dec 26 2020, 06:56 AM
HalfMoon
Hey guys , just a thought. You are effectively sh... Dec 26 2020, 08:41 AM
Superhawk996
That said, more tinkering (size changes) may yie... Dec 26 2020, 10:00 AM
Charles Freeborn
Hey guys , just a thought. You are effectively s... Dec 26 2020, 04:29 PM
mb911 An eccentric wheel would do what you are looking f... Dec 26 2020, 10:45 AM
HalfMoon
An eccentric wheel would do what you are looking ... Dec 26 2020, 11:03 AM
Superhawk996
[quote name='mb911' post='2878090' date='Dec 26 2... Dec 26 2020, 11:55 AM
brant There is a bolt on solution for this
Faster shift... Dec 26 2020, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:29 AM |
