> Increasing clutch cable transaxle pulley diameter
HalfMoon
post Dec 23 2020, 07:55 PM
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley?
Obviously the housing would have to be modified that much goes without saying.
My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift).
Direct experience with this modification very much sought.
gereed75
post Dec 24 2020, 09:14 AM
It is possible to change the pull ratio at the pulley. It would require the pulley to be some sort of cam lobe shape. The first example that comes to mind is the throttle cable cam/ pulley on a 944 throttle for those that might be familiar.
Lotta work for very little gain I suspect
Boy this thread has been all over the map - must be a holiday thing!
HalfMoon   Increasing clutch cable transaxle pulley diameter   Dec 23 2020, 07:55 PM
914e   Has anyone ever experimented with increasing the ...   Dec 23 2020, 08:15 PM
windforfun   Why bother? Get a life.   Dec 23 2020, 08:17 PM
HalfMoon   Why bother? Get a life. Hey chum, what's y...   Dec 23 2020, 10:04 PM
porschetub   Why bother? Get a life. You have got that backw...   Dec 23 2020, 11:15 PM
BillC   The clutch cable pulley doesn't do anything ex...   Dec 23 2020, 08:17 PM
GregAmy   All of the above. That's not how a pulley work...   Dec 23 2020, 08:36 PM
Spoke   Or convert to hydraulic. If you want to clean u...   Dec 24 2020, 01:06 PM
bdstone914   Has anyone ever experimented with increasing the ...   Dec 23 2020, 11:08 PM
Charles Freeborn   [quote name='HalfMoon' post='2877563' date='Dec 2...   Dec 23 2020, 11:26 PM
HalfMoon   [quote name='HalfMoon' post='2877563' date='Dec ...   Dec 24 2020, 08:34 AM
HalfMoon   [quote name='HalfMoon' post='2877563' date='Dec 2...   Dec 24 2020, 08:35 AM
914Sixer   Something else to ponder from Tangerine Racing   Dec 24 2020, 09:11 AM
HalfMoon   Something else to ponder from Tangerine Racing ...   Dec 24 2020, 09:56 AM
gereed75   It is possible to change the pull ratio at the pul...   Dec 24 2020, 09:14 AM
HalfMoon   It is possible to change the pull ratio at the pu...   Dec 24 2020, 09:57 AM
old914dog   It is possible to change the pull ratio at the p...   Dec 24 2020, 10:46 AM
stownsen914   It is possible to change the pull ratio at the pu...   Dec 26 2020, 07:08 AM
Chris914n6   Change your technique slowfoot :poke: *nothing...   Dec 24 2020, 04:06 PM
wattele   I was thingking about converting to hydraulic. My ...   Dec 25 2020, 11:47 AM
Mark Henry   I was thingking about converting to hydraulic. My...   Dec 26 2020, 09:55 AM
Mikey914   Hey guys , just a thought. You are effectively sho...   Dec 26 2020, 06:56 AM
HalfMoon   Hey guys , just a thought. You are effectively sh...   Dec 26 2020, 08:41 AM
Superhawk996   That said, more tinkering (size changes) may yie...   Dec 26 2020, 10:00 AM
Charles Freeborn   Hey guys , just a thought. You are effectively s...   Dec 26 2020, 04:29 PM
mb911   An eccentric wheel would do what you are looking f...   Dec 26 2020, 10:45 AM
HalfMoon   An eccentric wheel would do what you are looking ...   Dec 26 2020, 11:03 AM
Superhawk996   [quote name='mb911' post='2878090' date='Dec 26 2...   Dec 26 2020, 11:55 AM
brant   There is a bolt on solution for this Faster shift...   Dec 26 2020, 02:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:29 AM
