| HalfMoon |
Dec 23 2020, 07:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley?
Obviously the housing would have to be modified that much goes without saying. My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift). Direct experience with this modification very much sought. |
| gereed75 |
Dec 24 2020, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
It is possible to change the pull ratio at the pulley. It would require the pulley to be some sort of cam lobe shape. The first example that comes to mind is the throttle cable cam/ pulley on a 944 throttle for those that might be familiar.
Lotta work for very little gain I suspect Boy this thread has been all over the map - must be a holiday thing! |
| HalfMoon |
Dec 24 2020, 09:57 AM
It is possible to change the pull ratio at the pulley. It would require the pulley to be some sort of cam lobe shape. The first example that comes to mind is the throttle cable cam/ pulley on a 944 throttle for those that might be familiar. Lotta work for very little gain I suspect Boy this thread has been all over the map - must be a holiday thing! Hmmm. Interesting thought. |
| old914dog |
Dec 24 2020, 10:46 AM
Member ![]() ![]() Group: Members Posts: 74 Joined: 28-August 04 From: dallas,tx Member No.: 2,643 Region Association: None
It is possible to change the pull ratio at the pulley. It would require the pulley to be some sort of cam lobe shape. The first example that comes to mind is the throttle cable cam/ pulley on a 944 throttle for those that might be familiar. Lotta work for very little gain I suspect Boy this thread has been all over the map - must be a holiday thing! Hmmm. Interesting thought. I appreciate the disease of going faster. It is what makes cars go faster. With the 901 tranny, use caution. In a track only 914, I put a 5.5in clutch with a crazy lite flywheel, very close ratio gears.....thinking I could shift with the MGs and other competitors, which afterwards I learned had dog boxes. In one weekend I smoked 4 sycros. The box just was not designed for "bang" shifting. Just an old fart with his opinion. Merry Christmas |
HalfMoon Increasing clutch cable transaxle pulley diameter Dec 23 2020, 07:55 PM
914e
Has anyone ever experimented with increasing the ... Dec 23 2020, 08:15 PM
windforfun Why bother? Get a life. Dec 23 2020, 08:17 PM
HalfMoon
Hey chum, what's y... Dec 23 2020, 10:04 PM
porschetub
You have got that backw... Dec 23 2020, 11:15 PM
BillC The clutch cable pulley doesn't do anything ex... Dec 23 2020, 08:17 PM
GregAmy All of the above. That's not how a pulley work... Dec 23 2020, 08:36 PM
Spoke
Or convert to hydraulic.
If you want to clean u... Dec 24 2020, 01:06 PM
bdstone914
Has anyone ever experimented with increasing the ... Dec 23 2020, 11:08 PM
Charles Freeborn
[quote name='HalfMoon' post='2877563' date='Dec 2... Dec 23 2020, 11:26 PM
HalfMoon
[quote name='HalfMoon' post='2877563' date='Dec ... Dec 24 2020, 08:34 AM
HalfMoon
[quote name='HalfMoon' post='2877563' date='Dec 2... Dec 24 2020, 08:35 AM
914Sixer Something else to ponder from Tangerine Racing Dec 24 2020, 09:11 AM
HalfMoon
... Dec 24 2020, 09:56 AM
stownsen914
It is possible to change the pull ratio at the pu... Dec 26 2020, 07:08 AM
Chris914n6 Change your technique slowfoot :poke:
*nothing... Dec 24 2020, 04:06 PM
wattele I was thingking about converting to hydraulic.
My ... Dec 25 2020, 11:47 AM
Mark Henry
My... Dec 26 2020, 09:55 AM
Mikey914 Hey guys , just a thought. You are effectively sho... Dec 26 2020, 06:56 AM
HalfMoon
Hey guys , just a thought. You are effectively sh... Dec 26 2020, 08:41 AM
Superhawk996
That said, more tinkering (size changes) may yie... Dec 26 2020, 10:00 AM
Charles Freeborn
Hey guys , just a thought. You are effectively s... Dec 26 2020, 04:29 PM
mb911 An eccentric wheel would do what you are looking f... Dec 26 2020, 10:45 AM
HalfMoon
An eccentric wheel would do what you are looking ... Dec 26 2020, 11:03 AM
Superhawk996
[quote name='mb911' post='2878090' date='Dec 26 2... Dec 26 2020, 11:55 AM
brant There is a bolt on solution for this
Faster shift... Dec 26 2020, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:59 AM |
