| pcdarks |
Dec 23 2020, 05:41 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
After many responses to converting to carburetion I've decided to look into cleaning up and using the stock system. My concern is the boots that go over the fuel injectors are ripped off and the main harness outer housing has turned so brittle that It will probably break if moved very much. I assume I will be changing all of the fuel and air hoses but the are a few connections that are proprietary that look like they are in bad shape. Where would I go for replacements. If I'm going to do this I'm going to do it clean. Thanks.
| mepstein |
Dec 24 2020, 10:57 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
“FWIW the plastic connectors are of the same material as the 50 year old brake fluid reservoirs on all 914s which still serve their purpose, so this is no cause for concern.”
Not really a good comparison. Brake fluid reservoirs don’t live in a hot engine bay with current running through. Many of the connectors on 30-50 year old Porsche’s are failing. If you reuse a 50 year old connector, will it last another 10-20 years and why take the chance if you can get all new. |
| Mikey914 |
Dec 24 2020, 03:21 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
“FWIW the plastic connectors are of the same material as the 50 year old brake fluid reservoirs on all 914s which still serve their purpose, so this is no cause for concern.” Not really a good comparison. Brake fluid reservoirs don’t live in a hot engine bay with current running through. Many of the connectors on 30-50 year old Porsche’s are failing. If you reuse a 50 year old connector, will it last another 10-20 years and why take the chance if you can get all new. Maybe the anology is not apples to apples, but what Jeff is saying is the connectors used are of the same durable plastic that factory used in much more demanding areas. The plastic is not usually a big issue. It’s the wires and connectors. Jeff does good work no doubt about it. |
pcdarks Cleaning up the stock fuel injection. Dec 23 2020, 05:41 PM
Rob-O You’d go to Jeff Bowlsby and buy a new harness. ... Dec 23 2020, 05:50 PM
porschetub
You’d go to Jeff Bowlsby and buy a new harness.... Dec 24 2020, 02:13 PM
FlacaProductions 914Rubber.com is your friend
Here's a link to ... Dec 23 2020, 05:54 PM
mepstein Jeff reuses your old connectors. 914rubber and res... Dec 23 2020, 07:28 PM
JeffBowlsby
Jeff reuses your old connectors. 914rubber and re... Dec 24 2020, 10:31 AM
Montreal914 And this place sells the connectors... Might be ot... Dec 23 2020, 07:46 PM
JamesM
And this place sells the connectors... Might be o... Dec 24 2020, 01:06 PM
JamesM
[quote name='Montreal914' post='2877557' date='De... Dec 24 2020, 01:09 PM
rhodyguy How much of the FI system don't you have? Dec 23 2020, 10:16 PM
pcdarks
i... Dec 23 2020, 10:21 PM
tvdinnerbythepool That rebuild connector kit is awesome! Man I w... Dec 24 2020, 07:22 AM
914werke :agree: :headbanger: :headbanger: :headbanger: Dec 24 2020, 10:35 AM
913B Great resource materials, just bookmarked. Dec 24 2020, 01:40 PM
JamesM
After many responses to converting to carburetion... Dec 24 2020, 01:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:39 AM |
