> Weber mixture screws
dumbjim
post Dec 21 2020, 09:27 AM
Hi all, I spent yesterday fooling around with my weber idf 40's. by following mrbubbleheads instructions. With my snail, I got all four barrels pulling the same by adjusting the air bleed screws. I then moved on to the mixture screw. The mixture screws have absolutely no effect on how the engine is running. I can back them out or screw them in and there's not change in the idle. Is there something else going on here? In general, after adjusting the bleed screws, the engine is running pretty smooth. Any ideas? Thanks for reading.
rhodyguy
post Dec 25 2020, 09:55 AM
One has a jam nut and one doesn't. How could they get mixed up? Fwiw, if running the idle air mix screw in to gently seated with no effect on the idle there may be a problem with the idle jet for that Venturi. Every time you make a adj you need to wait for a bit. The change will not be immediate.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:42 AM
