| HalfMoon |
Dec 23 2020, 07:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Has anyone ever experimented with increasing the diameter of the transaxle clutch cable pulley?
Obviously the housing would have to be modified that much goes without saying. My wondering on this idea would be to shorten the "throw" at the pedal with the hope of increasing shift speed (I've converted to a cable shift). Direct experience with this modification very much sought. |
| Mikey914 |
Dec 26 2020, 06:56 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Hey guys , just a thought. You are effectively shortening the cable length, so why not just tighten the cable to preload the clutch to the point you desire. Anything you would do would have a diminished rate of return.
| HalfMoon |
Dec 26 2020, 08:41 AM
Hey guys , just a thought. You are effectively shortening the cable length, so why not just tighten the cable to preload the clutch to the point you desire. Anything you would do would have a diminished rate of return. True! I tried this by adding a spacer between the adjuster and the fork rod end but unfortunately, any preload (in this sbc application) was disallowing the clutch to fully disengage thus making for a clutch slip under hard acceleration. That said, more tinkering (size changes) may yield a result. Would it ultimately shorten the throw? I have doubts it would be noticable. |
HalfMoon Increasing clutch cable transaxle pulley diameter Dec 23 2020, 07:55 PM
914e
Has anyone ever experimented with increasing the ... Dec 23 2020, 08:15 PM
windforfun Why bother? Get a life. Dec 23 2020, 08:17 PM
HalfMoon
Hey chum, what's y... Dec 23 2020, 10:04 PM
porschetub
You have got that backw... Dec 23 2020, 11:15 PM
BillC The clutch cable pulley doesn't do anything ex... Dec 23 2020, 08:17 PM
GregAmy All of the above. That's not how a pulley work... Dec 23 2020, 08:36 PM
Spoke
Or convert to hydraulic.
If you want to clean u... Dec 24 2020, 01:06 PM
bdstone914
Has anyone ever experimented with increasing the ... Dec 23 2020, 11:08 PM
Charles Freeborn
[quote name='HalfMoon' post='2877563' date='Dec 2... Dec 23 2020, 11:26 PM
HalfMoon
[quote name='HalfMoon' post='2877563' date='Dec ... Dec 24 2020, 08:34 AM
HalfMoon
[quote name='HalfMoon' post='2877563' date='Dec 2... Dec 24 2020, 08:35 AM
914Sixer Something else to ponder from Tangerine Racing Dec 24 2020, 09:11 AM
HalfMoon
... Dec 24 2020, 09:56 AM
gereed75 It is possible to change the pull ratio at the pul... Dec 24 2020, 09:14 AM
HalfMoon
It is possible to change the pull ratio at the pu... Dec 24 2020, 09:57 AM
old914dog
It is possible to change the pull ratio at the p... Dec 24 2020, 10:46 AM
stownsen914
It is possible to change the pull ratio at the pu... Dec 26 2020, 07:08 AM
Chris914n6 Change your technique slowfoot :poke:
*nothing... Dec 24 2020, 04:06 PM
wattele I was thingking about converting to hydraulic.
My ... Dec 25 2020, 11:47 AM
Mark Henry
My... Dec 26 2020, 09:55 AM
Superhawk996
That said, more tinkering (size changes) may yie... Dec 26 2020, 10:00 AM
Charles Freeborn
Hey guys , just a thought. You are effectively s... Dec 26 2020, 04:29 PM
mb911 An eccentric wheel would do what you are looking f... Dec 26 2020, 10:45 AM
HalfMoon
An eccentric wheel would do what you are looking ... Dec 26 2020, 11:03 AM
Superhawk996
[quote name='mb911' post='2878090' date='Dec 26 2... Dec 26 2020, 11:55 AM
brant There is a bolt on solution for this
Faster shift... Dec 26 2020, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:51 AM |
