AA performance clyinder set Ring placement |
pcdarks |
Jan 3 2021, 03:58 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I recently purchased a set of 1.7 Liter pistons and cylinders for my 72 914 Porsche from AA performance. I noticed that the rings are installed and the pistons are in the cylinders. Is it necessary to remove the pistons to configure the ring spacing or is it already done? Can anyonre tell me how they spaced the ring gaps around the piston? In the old days compression and oil ring gap would be alternating in the 9 and 3 o'clock position.thanks
pcdarks |
Jan 4 2021, 11:22 AM
Good call to do a dis assembly. Make sure everything is OK. What configuration do you guys use? As I said before I used to set the ring gaps alternating at 9 and 3 o'clock. No gaps below so standing oil wouldn't leak through when the engine is off.
Lo-Fi Version | Time is now: 11th June 2024 - 12:31 PM |
