Transmission Vent |
Transmission Vent |
914e |
Jan 4 2021, 08:33 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I just changed motors a few weeks ago. Now on what was a dry transmission for months is leaking out the front seal like crazy. I had fixed the leaking output seals and speedo seal.
Could a plugged transmission vent cause it the seal to blow out? I drove it around on the old motor maybe only 15 miles. On the new motor it started leaking fairly quick. I was winding it out to about 6000-7000 rpm, will that cause more pressure in the transmission case? I pulled the vent and could not see much in it. I cleaned it out with brake cleaner, should there be valve or something in it? Or is it more likely the input shaft moved around enough mating back to the clutch that the decades old seal gave out? |
Krieger |
Jan 4 2021, 11:48 PM
Advanced Member Group: Members Posts: 4,729 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Random question: did the the engine you just installed have a pilot bearing in the flywheel? I had a problem once with a flywheel that did not have a pilot bearing. The input shaft from the trans had a noticeable leak despite having a brand new seal.
914e |
Jan 5 2021, 12:17 AM
Random question: did the the engine you just installed have a pilot bearing in the flywheel? I had a problem once with a flywheel that did not have a pilot bearing. The input shaft from the trans had a noticeable leak despite having a brand new seal. Yes, new pilot bearing. I ordered new seals tonight. One plus a spare, in case I screw up the first one. Since I have to take it apart I am replacing the throw out bearing too. Which I reused, I tried to force some new grease into it before using it. It didn't make noise and still doesn't. I'm sure there is some nice Arizona dirt in it though. |
Lo-Fi Version | Time is now: 12th June 2024 - 04:53 AM |
