| metalvolks |
Dec 20 2020, 01:23 PM
I'm new here ... Group: Members Posts: 0 Joined: 7-December 20 From: San Diego, CA Member No.: 24,961 Region Association: Southern California |
SOLD! SOLD! Hello everyone! Below is a complete list of 914 parts that I have for sale AS A LOT - I'm not really interested in parting pieces of it out any more.
I am looking to get $50 if you take everything listed below. I have hundreds of photos organized on a webpage with the link below. Everything sold as-is. Please take a look at the site before you contact me. Disregard the prices on the site. PICTURES OF ALL PARTS BELOW ARE HERE! http://paulmichaelrogers.com/porsche914parts/ Available Parts List: Engines/Engine Mechanical Parts: Engine Tin (1/2 Side Tin - 3 1.7/1.8, (4 Rear Tin), (Misc. Tin). Condition ranges from fair to good. Thermostat 2.0 Air Cleaner Housing - Surface Rust, but overall good condition Cooling Shroud (Good Condition) Muffler A/C Compressor (York) Stock (unknown condition) 1.7 (2 sets)/1.8/2.1 Cylinders (90 (2 sets) /92/96mm) - 92mm Cylinders and 96mm Cylinders SOLD, Pistons and Pins (most cylinders in good shape-all need to be honed. A few pistons have gouges and nicks. Pins would need to be polished) Pressure Plates Camshafts Crankshafts (Don't know for which motor) Engine Support Cross Bars - early style, later style 1.7 & ('74 1.8) Muffler Bracket Engine Electrical Parts: Engine Compartment Heater Blower Motor (TESTED-WORKING) 1 Alternator (with Cooling Vent) Interior/Mechanical: Shifter Seat Bracket Interior: Passenger Door Pulls Driver Door Pocket (Blue) A-Pillars - Poor to Fair Condition Ash Tray Driver Door Pocket Covers - Fair Condition Rear View Mirror - Fair Condition (Glass Issues) Upper Windshield Trim - Fair Condition Carpet Sill Trim Lot Seat Belt Receivers Misc. Interior Vents Dash Trim Plate - Very Straight Center Console Shifter Panel/Trim/Cover & Defrost Switch Console Box (Fair Condition) Body/Electrical: Tail Lights (2 lefts, 1 right) - Poor to Fair Condition (usable) Front Turn Signal Housings - Fair to Good Condition Horn Headlight Motors Headlight Assembly Lot - Fair Condition Fog Light Grill - Poor to Fair Condition (2 Cracks) A/C Evaporator, Fan and Enclosure DPD Misc. Relays, Switches, Actuators (Unknown Condition) Rear License Plate Lights Body: Rain Trays (2) - Both Have Small Cracks (can be fixed easily) License Plate Bracket Bumper Guards (Good Useable Condition) Spare Tire Well Section Brakes: Front Backing Plates - Good Condition Suspension: Aftermarket Unknown Brand Springs - Very High Spring Rate it Appears (Pair) Stock Rear Springs - 3 Red Stripes (2 Pair) Spring Hats, Seats & Hardware (Lot) Tie Rods Front Suspension, uprights, spindles, backing plates, crossmember Glass: 1969-1972 Driver's Window - Good condition Rear Glass - Good condition Misc.: Fuel Tank Fuel Tank Bumpers Windshield Washer Bottles Fuel Expansion Tanks (1 Plastic, 3 Metal) Charcoal Canister (2) Hood Springs and Hinges Factory Lug Wrench Thank you for looking! Paul SOLD parts list from this post: SOLD - OEM Oil Cooler - Good Condition - $40 SOLD - Cooling Shroud w/Alternator - Good Condition (small crack) - $40 SOLD - 2.0 Passenger Heat Exchanger - fair condition - $80 SOLD - 1.7/1.8 Stainless Steel Heat Exchangers (smoke tested ok) - Great Condition - $650 SOLD - 1.7 Long Block with heat exchangers (Complete Engine minus carbs, intake, distributor. Unknown Condition, Spins Freely - $450 SOLD - 1973 1.8 EC Case, Crank, Rods, Cam and Oil Pump - Good Condition - $200 SOLD - OE Oil Pump - 021 115 109A - $30 SOLD - 2.0 Oil Pickup and Windage - $40 SOLD - 1.7/1.8 Heat Exchangers (smoke tested ok) - Good Condition - Surface Rust and Paint, but solid - $150 SOLD - 1.8 Heads - Good Condition (No Visible Cracks) - 021 101 371 S - $120 (Set) SOLD - 2.0 Heads - Bare - 1 Head Great Condition (no cracks), 1 Head Machining Needed (Valve Seat Damage, 1 broken fin and 1 bent fin) - $250 (Pair) SOLD - Flywheel - $40 SOLD - Connecting Rods - $40 SOLD - Smog Pump - $40 SOLD - Engine Parts Lot1 (rocker arms, lifters, pushrods, springs, gaskets, etc) - $50 SOLD - Early 2.0 Muffler Bracket - $20 SOLD - Bosch Blue Coil - $20 SOLD - Pedal Board (Decent Condition) - $40 SOLD - 1973 914 Rolling Shell - Mainly surface rust. Hellhole, Rockers, Longs, Floors, Battery Tray, etc. solid. Small hole in floor, battery tray, spare tire well and trunk. Left Rear Shock Tower Needs Replacement. Has suspension, 5 steel "sport wheels", passenger windows and mechanism, etc. - $600 Engine Compartment Covers - $40 (white one is SOLD) SOLD - Engine Compartment Cover (Complete) With Rain Tray (Great Condition-No Dents) (Early Model) - $250 SOLD - Targa Top (Good-Usable Condition - small chip on corner - w/Front Latches) - $100 SOLD - Targa Top (Good Condition - w/ 1 Front Latch) - $125 SOLD - Front Hood (Great Condition - no dents, light surface rust, latch) - $125 SOLD - Dash Frame (Good Condition) - $80 SOLD - Front Bumper (Chrome Painted Black - Fair Condition) - Fairly straight with only a few dents- $80 SOLD - Rear Valance - poor to fair condition - $20 SOLD - Rear Calipers (Good Condition-Needs Rebuild) - $30/each SOLD - Rear Backing Plates - Fair Condition - $15/each SOLD - Weltmeister SP100 Rear Springs (Pair) - $60 SOLD - Wiper Arms Lot - $10 SOLD - 1 Alternator (with Cooling Vent) - $20 SOLD - Oil Filter Mounting Console - $15 |
| metalvolks |
Jan 4 2021, 03:10 PM
Happy Monday bump. Anyone need parts?
| 930cabman |
Jan 7 2021, 05:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| 930cabman |
Jan 12 2021, 04:26 PM
| metalvolks |
Jan 12 2021, 06:30 PM
Happy Monday bump. Anyone need parts? Make me a smokin deal: four decent 94mm cylinders, two rear backing plates and a pedal board. Any decent fog lamps? thank you Any of the above? I just PM'd you. Sorry for the delay. Paul |
metalvolks SOLD: 914 Parts Lot For Sale! $50 TAKE ALL! Dec 20 2020, 01:23 PM
rcarson25 I know he is new here at 914world, but I have know... Dec 20 2020, 03:16 PM
metalvolks
I know he is new here at 914world, but I have kno... Dec 21 2020, 04:42 PM
914sgofast2 PM sent for 1.8L heads, oil pickup & windage t... Dec 21 2020, 12:04 PM
metalvolks
PM sent for 1.8L heads, oil pickup & windage ... Dec 21 2020, 04:40 PM
frostyf Hi Paul, PM'd you about weltmeister SP100 Rear... Dec 21 2020, 12:23 PM
metalvolks
Hi Paul, PM'd you about weltmeister SP100 Rea... Dec 21 2020, 04:40 PM
porscheaddic Hi Paul,
Sent you a pm regarding the rods, and re... Dec 21 2020, 12:31 PM
metalvolks
Hi Paul,
Sent you a pm regarding the rods, and r... Dec 21 2020, 04:40 PM
jdbogart@self-serv.net Hi Paul -
I'm looking for the D-ring with the ... Dec 21 2020, 03:55 PM
second wind Hello Paul.....I would like dibs on the 2.0 stainl... Dec 21 2020, 04:58 PM
metalvolks
Hello Paul.....I would like dibs on the 2.0 stain... Dec 21 2020, 05:12 PM
second wind [quote name='metalvolks' post='2877018... Dec 21 2020, 10:31 PM
Ampex351 Paul, I need that antenna off of the white 914 bo... Dec 21 2020, 05:45 PM
metalvolks
Paul, I need that antenna off of the white 914 b... Dec 21 2020, 06:01 PM
metalvolks Friendly bump :) Dec 23 2020, 03:13 PM
metalvolks Another Friendly Bump! Dec 27 2020, 11:08 PM
Ampex351
Paul, am I missing s... Dec 28 2020, 12:35 AM
metalvolks
Paul, am I missing ... Dec 28 2020, 01:17 AM
930cabman Are the rear calipers and backing plates available... Dec 29 2020, 05:42 PM
metalvolks
Are the rear calipers and backing plates availabl... Dec 29 2020, 05:45 PM
metalvolks
Are the rear calipers and backing plates availabl... Dec 30 2020, 11:15 AM
930cabman
Are the rear calipers and backing plates availab... Dec 30 2020, 11:55 AM
kkid PM on its way for "Carpet Sill Trim Lot - ... Dec 29 2020, 06:57 PM
metalvolks
PM on its way for "Carpet Sill Trim Lot - ... Dec 29 2020, 07:12 PM
metalvolks
Happy Sunday everyone! Below is a complete li... Jan 2 2021, 12:14 PM
930cabman
Yes, do y... Jan 4 2021, 03:15 PM
metalvolks
Yes, do ... Jan 4 2021, 03:20 PM
metalvolks Thursday Bump! New prices added. Plenty of gre... Jan 7 2021, 03:45 PM
MFejsa Hi Paul, do you still have the 2.0 passenger heat ... Jan 10 2021, 02:47 PM
metalvolks
Hi Paul, do you still have the 2.0 passenger heat... Jan 12 2021, 06:26 PM
type47fan Hi Paul,
PM sent for smog pump.
Thanks,
Wayne Jan 11 2021, 12:39 AM
metalvolks
Hi Paul,
Thanks,
Wayne
... Jan 12 2021, 06:28 PM
Thierry Any chance you've got a fog switch available? Jan 12 2021, 03:40 PM
metalvolks
Any chance you've got a fog switch available?... Jan 12 2021, 06:29 PM
metalvolks Sold the 914 roller I had and a few other parts. P... Jan 15 2021, 01:00 PM
metalvolks Monday Bump! Jan 18 2021, 12:37 PM
metalvolks Bump! Jan 21 2021, 01:25 PM
metalvolks Happy Saturday bump! Great parts still availab... Jan 23 2021, 04:55 PM
metalvolks Bump! New prices, lower prices! Please let... Feb 10 2021, 01:50 PM
metalvolks Happy almost Friday bump! I still have lots of... Feb 18 2021, 08:21 PM
metalvolks Bump! Feb 28 2021, 08:00 PM
metalvolks Bump! Great parts available. Mar 7 2021, 03:57 PM
metalvolks BUMP! Mar 13 2021, 12:32 AM
cantley914 Hi Paul, do you have a motor mount part#039199231 ... Mar 16 2021, 02:13 PM
metalvolks
Hi Paul, do you have a motor mount part#039199231... Mar 16 2021, 03:44 PM
cantley914
Hi Paul, do you have a motor mount part#03919923... Mar 18 2021, 06:20 AM
metalvolks
[quote name='metalvolks' post='2900041' date='Mar... Mar 20 2021, 02:29 PM
rbzymek Greetings. Can you tell me about the mufflers? I... Mar 16 2021, 02:25 PM
metalvolks
Greetings. Can you tell me about the mufflers? ... Mar 16 2021, 03:31 PM
rbzymek
Greetings. Can you tell me about the mufflers? ... Mar 16 2021, 03:50 PM
Tdskip Had a chance to pick up my parts last weekend, goo... Mar 18 2021, 08:08 AM
metalvolks Happy Monday everyone! I have updated this pos... Mar 22 2021, 06:36 PM
metalvolks New price bump! I'm looking for these part... Mar 30 2021, 07:51 PM
scottthephotog Sent PM! Apr 1 2021, 06:06 PM
metalvolks
Sent PM!
Sent PM reply! Apr 1 2021, 07:42 PM
metalvolks Parts lot sold! Thanks porscheaddic!
The ... Apr 12 2021, 09:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th August 2026 - 02:40 PM |
