> broken stud on 914-6 oil tank
dwelle
post Jan 12 2021, 04:23 PM
i had to pull the oil tank out of my 914 to address a leak, and one of the mounting studs on the tank broke when i went to remove the nut. it broke about a 1/4" off of the tank.
quick google search last night didn't yield any good intel, what am i looking at to replace that stud?...
aturboman
post Jan 13 2021, 10:54 AM
I've fixed this problem before on 911 tanks. You'll need to carefully grind the broken stud flush to the the tank and clean the area to bare metal.
The only proper way to re-attached a stud to metal this thin is to carefully braze a new stud on and it will be as strong as the original
The tank is too thin for electric welding in my opinion even TIG is a challenge due to the vast differences in material thickness.
Also getting rid of all the oil or rust contamination for a proper electric weld is near impossible, brazing is much more tolerant in that regard.
dwelle   broken stud on 914-6 oil tank   Jan 12 2021, 04:23 PM
johnhora   you're talking about this in the drawing below...   Jan 12 2021, 04:57 PM
dwelle   yes, the stud on the right hand side of that diagr...   Jan 12 2021, 06:16 PM
Root_Werks   If there's enough thread, you might be able to...   Jan 12 2021, 06:22 PM
PanelBilly   RE: broken stud on 914-6 oil tank   Jan 12 2021, 06:32 PM
dwelle   yeah, there isn't enough of the stud left, and...   Jan 12 2021, 06:46 PM
johnhora   You could try to cut the old one flush at the base...   Jan 12 2021, 07:35 PM
Mark Henry   Or carefully weld a new stud on. I've done thi...   Jan 13 2021, 08:41 AM
gereed75   Maybe take a bolt with the same tread, grind the h...   Jan 13 2021, 10:21 AM
aturboman   I've fixed this problem before on 911 tanks. Y...   Jan 13 2021, 10:54 AM
rgalla9146   I've fixed this problem before on 911 tanks. ...   Jan 13 2021, 01:01 PM
dwelle   ok, thanks. i'm not going to attempt to weld ...   Jan 13 2021, 02:36 PM
Cairo94507   Personally, I would email @mb911 and explain wha...   Jan 13 2021, 02:46 PM
dwelle   Personally, I would email [b]@[url=http://www.91...   Jan 13 2021, 03:58 PM
mepstein   :agree: someone with the right skills will repair ...   Jan 13 2021, 02:50 PM
mb911   Thats a tricky spot for sure.. that stud is brazed...   Jan 13 2021, 05:49 PM
mepstein   Is there a riv nut type of fitting that can be use...   Jan 13 2021, 06:12 PM
dwelle   i'm not messing with this. otherwise, the ...   Jan 13 2021, 08:23 PM
- Lo-Fi Version Time is now: 15th November 2026 - 10:25 AM
