| dwelle |
Jan 12 2021, 04:23 PM
Newbie ![]() Group: Members Posts: 13 Joined: 24-December 16 From: a town south of fresno Member No.: 20,693 Region Association: None |
i had to pull the oil tank out of my 914 to address a leak, and one of the mounting studs on the tank broke when i went to remove the nut. it broke about a 1/4" off of the tank.
quick google search last night didn't yield any good intel, what am i looking at to replace that stud?... |
| mb911 |
Jan 13 2021, 05:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,841 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Thats a tricky spot for sure.. that stud is brazed with a flange from the inside..That will be a tricky repair. A couple ways to go about it.. I think the best way would be to drill and tap then insert a stud and weld or brake in place. That will ensure proper centering.
dwelle broken stud on 914-6 oil tank Jan 12 2021, 04:23 PM
johnhora you're talking about this in the drawing below... Jan 12 2021, 04:57 PM
dwelle yes, the stud on the right hand side of that diagr... Jan 12 2021, 06:16 PM
Root_Werks If there's enough thread, you might be able to... Jan 12 2021, 06:22 PM
PanelBilly RE: broken stud on 914-6 oil tank Jan 12 2021, 06:32 PM
dwelle yeah, there isn't enough of the stud left, and... Jan 12 2021, 06:46 PM
johnhora You could try to cut the old one flush at the base... Jan 12 2021, 07:35 PM
Mark Henry Or carefully weld a new stud on. I've done thi... Jan 13 2021, 08:41 AM
gereed75 Maybe take a bolt with the same tread, grind the h... Jan 13 2021, 10:21 AM
aturboman I've fixed this problem before on 911 tanks. Y... Jan 13 2021, 10:54 AM
rgalla9146
I've fixed this problem before on 911 tanks. ... Jan 13 2021, 01:01 PM
dwelle ok, thanks. i'm not going to attempt to weld ... Jan 13 2021, 02:36 PM
Cairo94507 Personally, I would email @mb911 and explain wha... Jan 13 2021, 02:46 PM
dwelle
Personally, I would email [b]@[url=http://www.91... Jan 13 2021, 03:58 PM
mepstein :agree: someone with the right skills will repair ... Jan 13 2021, 02:50 PM
mepstein Is there a riv nut type of fitting that can be use... Jan 13 2021, 06:12 PM
dwelle
i'm not messing with this. otherwise, the ... Jan 13 2021, 08:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 10:25 AM |
