| Geezer914 |
Jan 13 2021, 03:53 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,378 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
VDO no longer makes them, any other gauges out there?
| mate914 |
Jan 14 2021, 09:32 AM
Matt ![]() ![]() ![]() Group: Members Posts: 951 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
If I may ask? Which spark plug do you install CHT probe on? I would like to know for both the six and four cylinders.
Thank you. |
| Mark Henry |
Jan 14 2021, 09:57 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
If I may ask? Which spark plug do you install CHT probe on? I would like to know for both the six and four cylinders. Thank you. /4 the #3 cylinder runs the hottest. /6 it doesn't matter as much, some say #1, some say #6....I used #1 just because it's the easiest to run to. Edit: For the /6 the #1 cylinder is the easiest for me to get to as I'm twin plug and I have a lift. I have my sensor on the lower #1 plug hole. On a standard 6 plug engine the 4/5/6 side may be easier to get to. This is important because you must take care not to twist or cut wires on plug install. On my six I cut/notched the plug hole seal for the CHT sensor wires. |
Geezer914 Cylinder head temperature gauge Jan 13 2021, 03:53 PM
BeatNavy Oh yeah. At least a few of us use this one:
http... Jan 13 2021, 04:20 PM
Olympic 914
htt... Jan 13 2021, 05:26 PM
barefoot Here's mine
https://www.ebay.com/itm/Digital-... Jan 13 2021, 05:01 PM
930cabman I just ordered a new set of VDO gauges, oil temp, ... Jan 13 2021, 05:56 PM
jeffdon I got mine from https://www.aircraftspruce.com/
T... Jan 13 2021, 07:01 PM
Mark Henry I have a micro1000 from Aircraft Spruce, the small... Jan 13 2021, 09:36 PM
Charles Freeborn http://thesensorconnection.com/category/ch...all-c... Jan 14 2021, 01:03 AM
Geezer914 Thanks for the replies, went with a Dakota Digital... Jan 14 2021, 08:35 AM
veltror https://kaefertuer.com/produkt/zylinderkopf...ge-1... Jan 14 2021, 03:55 PM
930cabman
https://kaefertuer.com/produkt/zylinderkopf...ge-... Jan 14 2021, 04:12 PM
pete000 I have a NOS MIB VDO CHT stashed away... Jan 14 2021, 06:23 PM
FlacaProductions LOL - NOS MIB VDO CHT.
Very cool but not temperat... Jan 14 2021, 06:30 PM
930cabman Can someone educate me with regards to "tempe... Jan 14 2021, 07:15 PM
davesprinkle
Can someone educate me with regards to "temp... Jan 14 2021, 08:10 PM
FlacaProductions as i understand it - and i could be wrong - non-te... Jan 14 2021, 09:07 PM
barefoot
as i understand it - and i could be wrong - non-t... Jan 15 2021, 10:06 AM
FlacaProductions
as i understand it - and i could be wrong - non-... Jan 15 2021, 07:01 PM
Highland I think Ratwell has a pretty good explanation:
ht... Jan 14 2021, 10:15 PM
aharder I had a VDO for years and then it failed. I ended ... Jan 14 2021, 10:29 PM
narino
I had a VDO for years and then it failed. I ended... Jan 15 2021, 03:44 PM
930cabman
[quote name='aharder' post='2883082' date='Jan 14... Jan 15 2021, 05:28 PM
Krieger @Mark Henry did you need to make any modification... Aug 1 2022, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 02:10 AM |
