> Cylinder head temperature gauge
Geezer914
post Jan 13 2021, 03:53 PM
Geezer914
VDO no longer makes them, any other gauges out there?
FlacaProductions
post Jan 14 2021, 09:07 PM
as i understand it - and i could be wrong - non-temperature compensated gauges will read out higher as the ambient temperature goes up and lower as it goes down. ie: if your engine temp is (for example) 250 at 72 degrees, a non-compensated display will show 260 at 82.
temp-compensated will show 250 no matter the ambient temp.
barefoot
post Jan 15 2021, 10:06 AM
QUOTE(FlacaProductions @ Jan 14 2021, 10:07 PM) *
Not true, sorry.
Thermocouple based cylinder head temperature gauges use a bimetal construction that generates a voltage if one end is heated (or cooled). Thermocoulpes will measure the temperature DIFFERENCE between the hot end and the other end. Cold junction compensation introduces a measurement at the cold end then does an addition to read the actual temperature at the hot end, not just the difference.
i verified mine by placing the hot end in ~ boiling water as a bench test and got 210 degrees. Cooled to room temperature and the gauge read 73, so i know I'm reading actual head temps.
Hope this helps
Geezer914   Cylinder head temperature gauge   Jan 13 2021, 03:53 PM
BeatNavy   Oh yeah. At least a few of us use this one: http...   Jan 13 2021, 04:20 PM
Olympic 914   Oh yeah. At least a few of us use this one: htt...   Jan 13 2021, 05:26 PM
barefoot   Here's mine https://www.ebay.com/itm/Digital-...   Jan 13 2021, 05:01 PM
930cabman   I just ordered a new set of VDO gauges, oil temp, ...   Jan 13 2021, 05:56 PM
jeffdon   I got mine from https://www.aircraftspruce.com/ T...   Jan 13 2021, 07:01 PM
Mark Henry   I have a micro1000 from Aircraft Spruce, the small...   Jan 13 2021, 09:36 PM
Charles Freeborn   http://thesensorconnection.com/category/ch...all-c...   Jan 14 2021, 01:03 AM
Geezer914   Thanks for the replies, went with a Dakota Digital...   Jan 14 2021, 08:35 AM
mate914   If I may ask? Which spark plug do you install CHT ...   Jan 14 2021, 09:32 AM
Mark Henry   If I may ask? Which spark plug do you install CHT...   Jan 14 2021, 09:57 AM
veltror   https://kaefertuer.com/produkt/zylinderkopf...ge-1...   Jan 14 2021, 03:55 PM
930cabman   https://kaefertuer.com/produkt/zylinderkopf...ge-...   Jan 14 2021, 04:12 PM
pete000   I have a NOS MIB VDO CHT stashed away...   Jan 14 2021, 06:23 PM
FlacaProductions   LOL - NOS MIB VDO CHT. Very cool but not temperat...   Jan 14 2021, 06:30 PM
930cabman   Can someone educate me with regards to "tempe...   Jan 14 2021, 07:15 PM
davesprinkle   Can someone educate me with regards to "temp...   Jan 14 2021, 08:10 PM
FlacaProductions   as i understand it - and i could be wrong - non-te...   Jan 14 2021, 09:07 PM
barefoot   as i understand it - and i could be wrong - non-t...   Jan 15 2021, 10:06 AM
FlacaProductions   as i understand it - and i could be wrong - non-...   Jan 15 2021, 07:01 PM
Highland   I think Ratwell has a pretty good explanation: ht...   Jan 14 2021, 10:15 PM
aharder   I had a VDO for years and then it failed. I ended ...   Jan 14 2021, 10:29 PM
narino   I had a VDO for years and then it failed. I ended...   Jan 15 2021, 03:44 PM
930cabman   [quote name='aharder' post='2883082' date='Jan 14...   Jan 15 2021, 05:28 PM
Krieger   @Mark Henry did you need to make any modification...   Aug 1 2022, 04:40 PM
- Lo-Fi Version Time is now: 1st November 2026 - 02:08 AM
