| Geezer914 |
Jan 13 2021, 03:53 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,378 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
VDO no longer makes them, any other gauges out there?
| FlacaProductions |
Jan 14 2021, 09:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,290 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
as i understand it - and i could be wrong - non-temperature compensated gauges will read out higher as the ambient temperature goes up and lower as it goes down. ie: if your engine temp is (for example) 250 at 72 degrees, a non-compensated display will show 260 at 82.
temp-compensated will show 250 no matter the ambient temp. |
| barefoot |
Jan 15 2021, 10:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
as i understand it - and i could be wrong - non-temperature compensated gauges will read out higher as the ambient temperature goes up and lower as it goes down. ie: if your engine temp is (for example) 250 at 72 degrees, a non-compensated display will show 260 at 82. temp-compensated will show 250 no matter the ambient temp. Not true, sorry. Thermocouple based cylinder head temperature gauges use a bimetal construction that generates a voltage if one end is heated (or cooled). Thermocoulpes will measure the temperature DIFFERENCE between the hot end and the other end. Cold junction compensation introduces a measurement at the cold end then does an addition to read the actual temperature at the hot end, not just the difference. i verified mine by placing the hot end in ~ boiling water as a bench test and got 210 degrees. Cooled to room temperature and the gauge read 73, so i know I'm reading actual head temps. Hope this helps |
| FlacaProductions |
Jan 15 2021, 07:01 PM
as i understand it - and i could be wrong - non-temperature compensated gauges will read out higher as the ambient temperature goes up and lower as it goes down. ie: if your engine temp is (for example) 250 at 72 degrees, a non-compensated display will show 260 at 82. temp-compensated will show 250 no matter the ambient temp. Not true, sorry. Thermocouple based cylinder head temperature gauges use a bimetal construction that generates a voltage if one end is heated (or cooled). Thermocoulpes will measure the temperature DIFFERENCE between the hot end and the other end. Cold junction compensation introduces a measurement at the cold end then does an addition to read the actual temperature at the hot end, not just the difference. i verified mine by placing the hot end in ~ boiling water as a bench test and got 210 degrees. Cooled to room temperature and the gauge read 73, so i know I'm reading actual head temps. Hope this helps Perfect, thank you and my apologies. One thing I hate is when untrue/wrong information is spread here and I hate that I'm part of doing so. Thanks for setting me - and the record - straight. |
Geezer914 Cylinder head temperature gauge Jan 13 2021, 03:53 PM
BeatNavy Oh yeah. At least a few of us use this one:
http... Jan 13 2021, 04:20 PM
Olympic 914
htt... Jan 13 2021, 05:26 PM
barefoot Here's mine
https://www.ebay.com/itm/Digital-... Jan 13 2021, 05:01 PM
930cabman I just ordered a new set of VDO gauges, oil temp, ... Jan 13 2021, 05:56 PM
jeffdon I got mine from https://www.aircraftspruce.com/
T... Jan 13 2021, 07:01 PM
Mark Henry I have a micro1000 from Aircraft Spruce, the small... Jan 13 2021, 09:36 PM
Charles Freeborn http://thesensorconnection.com/category/ch...all-c... Jan 14 2021, 01:03 AM
Geezer914 Thanks for the replies, went with a Dakota Digital... Jan 14 2021, 08:35 AM
mate914 If I may ask? Which spark plug do you install CHT ... Jan 14 2021, 09:32 AM
Mark Henry
If I may ask? Which spark plug do you install CHT... Jan 14 2021, 09:57 AM
veltror https://kaefertuer.com/produkt/zylinderkopf...ge-1... Jan 14 2021, 03:55 PM
930cabman
https://kaefertuer.com/produkt/zylinderkopf...ge-... Jan 14 2021, 04:12 PM
pete000 I have a NOS MIB VDO CHT stashed away... Jan 14 2021, 06:23 PM
FlacaProductions LOL - NOS MIB VDO CHT.
Very cool but not temperat... Jan 14 2021, 06:30 PM
930cabman Can someone educate me with regards to "tempe... Jan 14 2021, 07:15 PM
davesprinkle
Can someone educate me with regards to "temp... Jan 14 2021, 08:10 PM
Highland I think Ratwell has a pretty good explanation:
ht... Jan 14 2021, 10:15 PM
aharder I had a VDO for years and then it failed. I ended ... Jan 14 2021, 10:29 PM
narino
I had a VDO for years and then it failed. I ended... Jan 15 2021, 03:44 PM
930cabman
[quote name='aharder' post='2883082' date='Jan 14... Jan 15 2021, 05:28 PM
Krieger @Mark Henry did you need to make any modification... Aug 1 2022, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 02:09 AM |
