| Robarabian |
Jan 17 2021, 06:39 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 745 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
A few weeks ago I posted a photo of some heads I pulled off a motor I had purchased from another member that had some heads with valves that were not in alignment with each other. They were GEX heads, and all the postings agreed, don't waste too much time on them. I saved them for another day.
I had a set of AA 2.0 heads (brand new) that were slated for another motor but this is a stop gap engine to use till that one is built. I swapped heads, cleaned everything, and re assembled. Valves adjusted and mounted to my test stand. Fresh oil, O rings etc... Engine fired quickly and got the webers to the point where it idled reasonably and I was going to start adjusting them. At about the three - four minute point of idling and goosing the throttle a bit, I heard a bit of valve train noise, almost like a "POP" and I could hear clickcty Clack so I shut it down. I set the crank back to TDC #1 and checked the valves. (cold) 1,2,4 were good. #3 the intake valve was out of spec so I re-adjusted. re-checked the other three again, rotated the motor through and buttoned it back up. This was a week or two ago. Today, I decided to tinker again and same thing happened. All was good, engine was running real smooth. Goosed the throttle, started tuning carbs and again, "POP". #3 is loose. When I say "loose" it is going from .006 adjusted to .008 so it is loud enough to hear. Putting it another way, it sounds as a proper air cooled type 4 should, and then clickety clack, loud valvetrain. Cyl's #1, 2, 4 are in spec. I am setting Intakes at .006 and exhaust at .008. I replaced all the valve adjuster tappets when I swapped the heads with stock ones, not swivels or anything weird. This one is baffling me. Could I have valve adjusters out of alignment? Is the head just going through a normal cycle of stretching new valves when it got to operating temp? Am I losing my mind? I appreciate the input from the knowledge base here. Im a garage mechanic, not a pro shop and Im only recently delving back into the mechanicals of the 2.0... |
| Robarabian |
Jan 18 2021, 10:29 PM
Thank you for the insight.
So I did change out all the adjusters because the original ones were pretty buggered up, given the heads they came off of, I was not surprised. I did pull one lifter out of its bore while I was going through things just to look, and it looked good. Was flat, no scoring etc. Flashlight into the bore and I did not see anything that would have caused concern,.... It was on Cyl#2 intake. Today, I pulled the valve covers off and pulled all the rockers and reinspected everything. They looked good (no uneven wear, cracks etc...). Pushrods are straight. It was Cyl #4 intake that was the loose one. I had a Type 4 store set of bushings, so I spent the day fitting them and re-assembling the valve train. Before disassembly, I did look at everything and re-measured clearances cold. Everything but two were within spec, and at that, the .008 became .009, so not by much, but enough to be louder than it should when running. I think I found 2 that had "moved". Also, and I believe this is normal, not all the tappets hit the valves dead center, but are offset slightly, which I think I read was to allow the valve stem to rotate. Reassembled it all and ran it. I ran a solid 5 minutes and got the webers a bit more dialed in (flat spot so I am lean) but nothing went boom or click. Also re-pulled the valve covers and made sure all the adjuster nuts were tight (actually got some turn out of two of them). I will try it again next Friday, maybe I licked it. Then again, it could go pop, and I could be in to pulling all the lifters out to look at them, and the cam. You guys gave me some leads to pursue, Ill know more next week when I get shop time again. Thank you for chiming in. |
Robarabian Valve Train Question Jan 17 2021, 06:39 PM
porschetub Wow hard to nail this one down,never had this befo... Jan 18 2021, 06:42 PM
burton73 I am going to through this out. In 1979 I had a 19... Jan 18 2021, 07:05 PM
porschetub
I am going to through this out. In 1979 I had a 1... Jan 18 2021, 07:35 PM
Jake Raby As a general rule, loose valves occur from cam/lif... Jan 18 2021, 11:42 PM
Robarabian Thanks Jake, always honored to have your expertise... Jan 19 2021, 09:28 AM
Mark Henry Check your valve cover for the adjuster touching i... Jan 19 2021, 07:35 AM
VaccaRabite
Check your valve cover for the adjuster touching ... Jan 19 2021, 07:38 AM
Mark Henry
Check your valve cover for the adjuster touching... Jan 19 2021, 09:31 AM
Robarabian
[quote name='VaccaRabite' post='2884071' date='Ja... Jan 19 2021, 10:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 10:48 PM |
