> 2270(or so) Build
yeahmag
post Jan 8 2021, 12:47 PM
I'm starting to get the case(s) machined and inspected and parts ordered for my next generation engine. The car is mostly used for autocross.
78x96
96mm piston with 22mm wrist pin (stroker)
5.4" Type 1 Rod, 22mm wrist pin
WebCam 86b/86c
David Finch heads (from Len Hoffman many moons ago)
9.5:1 CR running on 91 octane pump gas
CB Dry Sump (heavily modified) or Thorsten Piper dry sump pump
Front mounted oil cooler
There are a few crank options out there now:
* DPR offset grind Type 1 journal
* AA Performance Forged Type 1 journal
* FAT Performance Forged Chevy journal
I've read about a few 80mm DPR cranks breaking, so I was planning on staying under 80mm as I like the car to be able to rev. I was considering Chevy journals for ease of assembly, but the two cranks I've read about breaking were 80mm/Chevy journals. Is there any new information on cranks out there? Any input on the config?
Jake Raby
post Jan 19 2021, 01:07 PM
Engine Surgeon
Run a 1.065"BC and then clearance the rods as necessary.
Don't worry about cam rigidity.
Blown59
post Jan 19 2021, 01:35 PM
QUOTE(Jake Raby @ Jan 19 2021, 01:07 PM) *
Jake, thank you for the info.
yeahmag   2270(or so) Build   Jan 8 2021, 12:47 PM
914werke   Following. Aaron interested in your approach to dr...   Jan 8 2021, 03:21 PM
yeahmag   I’ve been running the CB Pump successfully in my...   Jan 8 2021, 03:35 PM
Montreal914   Will definitely be following this thread. :popcor...   Jan 8 2021, 08:35 PM
wndsrfr   FAT uses new forgings & will supply you with a...   Jan 8 2021, 09:03 PM
Alapone   Definitely following this.   Jan 8 2021, 09:57 PM
yeahmag   I have NOS JE’s and AA cast iron cylinders that ...   Jan 8 2021, 10:17 PM
Montreal914   I have NOS JE’s and AA cast iron cylinders that...   Jan 8 2021, 10:34 PM
914werke   I used them on a 912E rebuild but that was only 20...   Jan 8 2021, 11:05 PM
groot   I have a 80x96 with birals. It's only run on t...   Jan 9 2021, 10:22 AM
yeahmag   I have a 80x96 with birals. It's only run on ...   Jan 9 2021, 12:01 PM
Jack Standz   I'm starting to get the case(s) machined and ...   Jan 9 2021, 11:15 AM
Mark Henry   Longevity you want the 78mm with T1 rod journals, ...   Jan 9 2021, 02:08 PM
groot   AA crank, chevy journals... this is kind of a part...   Jan 9 2021, 03:58 PM
Dave_Darling   Is the 78 stroke big enough to require a reduced b...   Jan 9 2021, 07:02 PM
Mark Henry   Is the 78 stroke big enough to require a reduced ...   Jan 9 2021, 08:48 PM
Montreal914   Is the 78 stroke big enough to require a reduced...   Jan 9 2021, 11:02 PM
Mark Henry   [quote name='Mark Henry' post='2881686' date='Jan...   Jan 10 2021, 07:59 AM
groot   Hmmmm... I didn't have much clearancing requir...   Jan 10 2021, 10:04 AM
Mark Henry   Hmmmm... I didn't have much clearancing requi...   Jan 14 2021, 02:02 PM
groot   It's the rods with that T4 combo and a big li...   Jan 14 2021, 04:02 PM
Blown59   Curiously... As a noob when it comes to T4 builds....   Jan 13 2021, 10:55 PM
groot   Curiously... As a noob when it comes to T4 builds...   Jan 14 2021, 03:56 PM
Dave_Darling   Curiously... As a noob when it comes to T4 builds...   Jan 14 2021, 07:08 PM
Blown59   Curiously... As a noob when it comes to T4 build...   Jan 17 2021, 03:38 PM
Jake Raby   [quote name='Dave_Darling' post='2883027' date='J...   Jan 18 2021, 11:45 PM
Blown59   I sort of understand what youre saying... I get...   Jan 19 2021, 10:31 AM
yeahmag   It's all about reducing the amount of case and...   Jan 14 2021, 12:27 PM
yeahmag   Kevin, What cam did you decide on for your 2316 b...   Jan 14 2021, 03:58 PM
groot   Aaron. 163/86b... not trying to turn 7000+... I ha...   Jan 14 2021, 04:04 PM
Jake Raby   Run a 1.065"BC and then clearance the rods as...   Jan 19 2021, 01:07 PM
Blown59   Run a 1.065"BC and then clearance the rods a...   Jan 19 2021, 01:35 PM
Mark Henry   You're worrying about the wrong thing, the cra...   Jan 20 2021, 06:53 AM
Jake Raby   You're worrying about the wrong thing, the cr...   Jan 20 2021, 07:57 AM
Mark Henry   You do realize high lift cams like the 163/86b req...   Jan 20 2021, 08:09 AM
Blown59   You do realize high lift cams like the 163/86b re...   Jan 20 2021, 03:06 PM
VaccaRabite   Everyone needs to learn one way or another. How ...   Jan 21 2021, 08:28 AM
Jake Raby   Everything I know about all the Porsche engines I ...   Jan 21 2021, 10:57 AM
yeahmag   Zach, That's exactly how I ended up where I a...   Jan 21 2021, 11:24 AM
Jake Raby   10.8 is too high for a 163/86B on 93 octane unless...   Jan 21 2021, 03:31 PM
yeahmag   Thanks, Jake. I'm really leaning towards the 8...   Jan 21 2021, 03:37 PM
Mark Henry   That's why I'm thinking of shooting for ...   Jan 21 2021, 03:51 PM
Mark Henry   What heads? With Len's heads you don't hav...   Jan 21 2021, 03:48 PM
yeahmag   They are heads from Len, but not Len's heads. ...   Jan 21 2021, 03:55 PM
- Lo-Fi Version Time is now: 19th June 2026 - 05:36 AM
