> How do YOU protect your transmission case from corrosion?, What coatings do you use?
Dr Evil
post Mar 8 2010, 10:56 PM
Send me your transmission!
I am trying to finish my notes to accompany the rebuild video (notes will be free) and I am wanting to pick your collective brains for info on corrosion prevention for the mag alloy case. What do you do? The factory coating only lasted a few years and is long gone now. On most peoples cases, it is the oil that keeps it from corroding (IMG:style_emoticons/default/wink.gif)
bkrantz
post Jan 17 2021, 08:39 PM
Has anyone tried T-9?
bbrock
post Jan 17 2021, 09:07 PM
QUOTE(bkrantz @ Jan 17 2021, 07:39 PM) *
Yes. Seems to be good stuff. I used it on my fan shroud and so far it has stayed a nice factory gray look so far (about 2 years indoors). I also treated my transmission case above with it a week before daubing on the Tectyl. I think the Tectyl will provide significantly more protection, but the T-9 is invisible and doesn't leave a waxy coating if you want to avoid it.
jd74914
post Jan 19 2021, 12:01 PM
Its alive
QUOTE(bbrock @ Jan 17 2021, 10:07 PM) *
Like Boeshield T-9?
I can't believe I never thought about using it. Works great on my table saw and jointer. (IMG:style_emoticons/default/smile.gif)
bbrock
post Jan 19 2021, 02:04 PM
QUOTE(jd74914 @ Jan 19 2021, 11:01 AM) *
Like Boeshield T-9?
And I can't believe I never thought about using it on my table saw! (IMG:style_emoticons/default/beer.gif)
jd74914
post Jan 19 2021, 04:21 PM
Its alive
QUOTE(bbrock @ Jan 19 2021, 03:04 PM) *
Like Boeshield T-9?
@bbrock
Light coat, buff off, then your favorite paste wax. Works wonders. My equipment is in an unheated garage which gets warmed up just for use in the winter so condensation is always an issue and since using T-9 I've stopped having table rust issues.
Edit: Make sure its really clean and relatively warm first so the propellant can evaporate in a timely fashion-or I've seen it get a bit gummy.
bbrock
post Jan 19 2021, 05:33 PM
QUOTE(jd74914 @ Jan 19 2021, 03:21 PM) *
Like Boeshield T-9?
@bbrock
@jd74914
(IMG:style_emoticons/default/thumb3d.gif) I've just been using paste wax. Of course that works fine but the instant indicator of when it wears is flash rust even in my low humidity world. Will be great to have that extra layer of protection soaked into the pores. Thanks for the tip!
Dr Evil   How do YOU protect your transmission case from corrosion?   Mar 8 2010, 10:56 PM
Krieger914   The one sitting on my garage floor is coated in wd...   Mar 8 2010, 10:58 PM
underthetire   Nickel plating, a little bling bling....   Mar 8 2010, 10:59 PM
McMark   I cover mine with 40 yr old German steel and don...   Mar 8 2010, 11:24 PM
Dr Evil   I know one can clear coat a clean one. There is th...   Mar 8 2010, 11:29 PM
bandjoey   MOTOR OIL and dirt works great! :lol4:   Mar 8 2010, 11:34 PM
Dr Evil   I know, I mentioned that :P   Mar 8 2010, 11:36 PM
Dr. Roger   I try to make sure at least one of my valve cover ...   Mar 8 2010, 11:43 PM
Rand   Is corrosion a serious issue? Rust on steel is a h...   Mar 9 2010, 12:26 AM
zymurgist   I think this could apply to /6 fans too... aren...   Mar 9 2010, 05:13 AM
Gint   Never bothered. I might want to at some point tho...   Mar 9 2010, 08:42 AM
Richard Casto   Mike, I started a long term test of a few cleanin...   Mar 9 2010, 08:44 AM
pcar916   ... would go with "CRC Heavy Duty Corrosion...   Mar 9 2010, 10:11 AM
Richard Casto   I should also mention that I was looking to go for...   Mar 9 2010, 08:56 AM
tat2dphreak   30 years of grease and gunk are keeping mine prist...   Mar 9 2010, 09:25 AM
SUNAB914   Eastwood, Aluma blast spray.   Mar 9 2010, 10:20 AM
davep   Pelican was going to sell Tectyl, but ran into pro...   Mar 9 2010, 12:43 PM
Richard Casto   I haven't heard of that CRC 3-36. I read that...   Mar 9 2010, 02:37 PM
turboman808   Got some exhaust spray from Chris last year that w...   Mar 9 2010, 02:59 PM
Drums66   Redline Tranny Juice(no corrosion) :wavebye: :sti...   Mar 9 2010, 03:43 PM
Richard Casto   Redline Tranny Juice(no corrosion) :wavebye: :st...   Mar 9 2010, 04:20 PM
Drums66   If you are talking interior, just make sure it...   Mar 9 2010, 05:04 PM
jmill   I have no idea of the cost on this stuff but they ...   Mar 9 2010, 06:25 PM
Downunderman   HPC S02   Mar 10 2010, 12:50 AM
kwales   From my mag casting days, the magnesium institute ...   Mar 10 2010, 10:19 AM
Tom_T   From my mag casting days, the magnesium institute...   Mar 10 2010, 02:24 PM
SUNAB914   Aluma blast: Eastwood   Mar 10 2010, 12:47 PM
Phoenix-MN   VHT high-temp clear   Mar 10 2010, 12:57 PM
Tom_T   VHT high-temp clear :agree: Paint is another...   Mar 10 2010, 02:13 PM
kwales   When working with new parts, you apply coatings, n...   Mar 10 2010, 05:02 PM
pcar916   I'm reviving this thread because I've just...   Nov 10 2011, 02:36 PM
bulitt   I have a 1949 Allis Chalmers tractor with some ori...   Nov 10 2011, 03:24 PM
bbrock   I'm reviving this old thread to provide an upd...   Jan 17 2021, 12:34 PM
ejm   I'm reviving this old thread to provide an up...   Jan 17 2021, 02:55 PM
rgalla9146   Every time I opened a painted trans it was a crapp...   Jan 17 2021, 05:15 PM
mepstein   Every time I opened a painted trans it was a crap...   Jan 17 2021, 07:27 PM
bkrantz   Has anyone tried T-9?   Jan 17 2021, 08:39 PM
bbrock   Has anyone tried T-9? Yes. Seems to be good st...   Jan 17 2021, 09:07 PM
jd74914   Has anyone tried T-9? Yes. Seems to be good s...   Jan 19 2021, 12:01 PM
bbrock   [quote name='bbrock' post='2883753' date='Jan 17 ...   Jan 19 2021, 02:04 PM
jd74914   Like Boeshield T-9? I can't believe I never...   Jan 19 2021, 04:21 PM
bbrock   [quote name='jd74914' post='2884139' date='Jan 1...   Jan 19 2021, 05:33 PM
914Sixer   I used LPS 3. Leaves a waxy coating.   Jan 18 2021, 07:56 AM
Montreal914   What was used to clean it and did it need to be gu...   Jan 18 2021, 11:56 AM
JmuRiz   I was going to spray mine with Gibbs, but forgot t...   Jan 18 2021, 09:56 PM
mepstein   I was going to spray mine with Gibbs, but forgot ...   Jan 18 2021, 10:29 PM
JmuRiz   Good point, worth a shot right :D My shiny billet...   Jan 19 2021, 09:08 AM
mlindner   I just cleaned mine really good and painted.....If...   Jan 19 2021, 04:12 PM
Jake Raby   When I started doing work for The Revs Institute t...   Jan 19 2021, 09:39 PM
mlindner   Thanks Jake, that looks like a great product. Best...   Jan 20 2021, 05:24 AM
barefoot   I cleaned & cleaned again and again, then pain...   Jan 20 2021, 08:26 AM
napasteve   I realize this is a dumb questions but here goes: ...   Jan 20 2021, 10:43 AM
DRPHIL914   I realize this is a dumb questions but here goes:...   Jan 20 2021, 12:48 PM
- Lo-Fi Version Time is now: 13th November 2026 - 05:21 AM
