DavidSweden |
Member ![]() ![]() Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
Hello,
What is the maximum allowable compression ratio difference between cylinders? 2056 motor AA big bore Thanks in advance |
DavidSweden |
I am installing some new heads because of damage to one of the spark plug holes and at the same time installing a 2056 AA piston & cylinder set. The engine is a stock 2.0 (stock cam) with D jet
The new heads have been fly cut at some time- cylinder 1 & 2 = 59cc and 3 & 4 = 57cc. Deck height = 1.2mm on all cylinders, and the AA piston valve cut outs = 7cc. This gives a compression ratio of 7.84:1 on cylinders 3 & 4 and 8.03:1 on cylinders 1 & 2 This is with no shims and no head gasket, so unless I get the cylinders or heads machined I am stuck with these low compression values. The compression ratios on each side of the engine are different I guess this is ok but I just want someone who knows to give me an opinion. Thanks in advance |
Lo-Fi Version | Time is now: 13th June 2024 - 04:44 AM |
