Best way to install push rod tubes for no leaks |
pcdarks |
Jan 22 2021, 10:42 AM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I'm getting ready to put my 1.7 back together and am wondering what you people do to insure that the push rod tubes don't leak. From what I saw taking it apart this is where most of my leaks came from. Is it possible? or were the tubes designed by the British? thanks.
flat4guy |
Jan 22 2021, 08:57 PM
Member Group: Members Posts: 444 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
In the VW world they now have spring loaded ones that always have tension on them - I have used 2 sets and no leaks 2 years later. About $100 for 8
Mark Henry |
Jan 23 2021, 10:42 AM
In the VW world they now have spring loaded ones that always have tension on them - I have used 2 sets and no leaks 2 years later. About $100 for 8 Maybe for a T1 but that won't work in a T4. My biggest trick is I use a 1" flap sander and give the bores a quick once over and I also debur any sharp edges before the final cleaning and install of the tubes. I use the dow 55 Oring lube slight twist as I install. Once done be very careful installing the retaining spring and Bob's yer uncle. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:49 AM |
