Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
mepstein |
Jan 28 2021, 02:45 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pete - Have you weighed a 914 trailing arm. They look heavy but really not that bad. I don't have one in front of me but I'm guessing a bare one at 12-15lbs.
Jan 28 2021, 03:28 PM
Pete - Have you weighed a 914 trailing arm. They look heavy but really not that bad. I don't have one in front of me but I'm guessing a bare one at 12-15lbs. I've handled three pairs of them over the years, with and without other parts on them, and they seemed like a heavy, strong, and inexpensive part for a mass-produced car. Kinda like early 911/912/911 steel crossmembers, before PAG moved to aluminum. I'd be curious to know their weight without bearings, etc.—as that would be the relevant comparison. In the old days, I could head down to EASY and very likely weigh one. Those days are gone, sadly. |
mepstein |
Jan 28 2021, 04:23 PM
Pete - Have you weighed a 914 trailing arm. They look heavy but really not that bad. I don't have one in front of me but I'm guessing a bare one at 12-15lbs. I've handled three pairs of them over the years, with and without other parts on them, and they seemed like a heavy, strong, and inexpensive part for a mass-produced car. Kinda like early 911/912/911 steel crossmembers, before PAG moved to aluminum. I'd be curious to know their weight without bearings, etc.—as that would be the relevant comparison. In the old days, I could head down to EASY and very likely weigh one. Those days are gone, sadly. I'll do it tomorrow if nobody beats me to it. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:32 AM |
