Can a rag get pass the type 4 fan?, Today's public service announcement. |
Mark Henry |
Jan 28 2021, 02:13 PM
Why yes it can. (IMG:style_emoticons/default/huh.gif)
Cause of 2.0 dropped seat solved, although the grease between the cylinders didn't help either. Attached thumbnail(s) |
Spoke |
Jan 28 2021, 05:45 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I did that once with my 911. I had a towel on the back bumper while I worked on the engine. It started up real nice then made some nasty sounds. The towel didn't make it past the fan belt and got jammed in the crank pulley. I had to cut the belt to get things free.
ClayPerrine |
Jan 29 2021, 10:44 AM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I did that once with my 911. I had a towel on the back bumper while I worked on the engine. It started up real nice then made some nasty sounds. The towel didn't make it past the fan belt and got jammed in the crank pulley. I had to cut the belt to get things free. Yep.. we all make mistakes. Years ago, when I still had a 2.0 in my red car, I accidentally knocked a small pair of vice grips into the fan and didn't notice it. When I started the car, it made a horrible racket. I shut it down quick. But not before it trashed the fan. I ended up pulling the injection and engine tin, and spent hours picking bits of the fan out of the cylinder and head fins. Luckily I had another fan to replace it. Funny.. the the vice grips were fine. I still have them and use them. Mistakes are how you learn. Hopefully your mistakes aren't too expensive. Clay |
Lo-Fi Version | Time is now: 11th June 2024 - 09:42 AM |
