| raynekat |
Jan 31 2021, 05:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,172 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Installing the 914Rubber fender liners....
They come with rivets for fastening the plastic liners to the mounting brackets. It quickly became apparent that installation was going to be difficult if I used the rivets. The rivets fasten the liner to the mounting brackets and then the brackets use your rocker panel and valance sheet metal bolts to hold the liner in place. So I opted to use speed nuts that sit on the mounting brackets so that hex headed metric screws could be used instead of the rivets. Here was the hardware and bracket ready to bolt into the car. The reason I went this will become apparent pretty quickly. Here's the leading edge (front) that utilizes the valance mounting bolt. In theory you could have put this in as a unit (bracket and liner) as you actually have access to the bolt that mounts the valence. The real problem with the rivet method is mounting the trailing edge (rear) bracket that uses the rocker cover bolt. You can't access the bolt to secure the bracket to the rocker cover as it's behind the liner. So with my method you mount the bare bracket first and then fasten the liner to the bracket. Here's a better view of the finished product. No way you're getting your hand in behind the liner to tighten or loosen the bracket with the liner in place. With the speed nut and hex head screws I used, you can easily take the liner off in a matter of minutes without removing the brackets at the valance and rocker panel. Inspection and cleaning is still an easy thing to accomplish. |
| mb911 |
Jan 31 2021, 08:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,832 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Installing the 914Rubber fender liners.... They come with rivets for fastening the plastic liners to the mounting brackets. It quickly became apparent that installation was going to be difficult if I used the rivets. The rivets fasten the liner to the mounting brackets and then the brackets use your rocker panel and valance sheet metal bolts to hold the liner in place. So I opted to use speed nuts that sit on the mounting brackets so that hex headed metric screws could be used instead of the rivets. Here was the hardware and bracket ready to bolt into the car. The reason I went this will become apparent pretty quickly. Here's the leading edge (front) that utilizes the valance mounting bolt. In theory you could have put this in as a unit (bracket and liner) as you actually have access to the bolt that mounts the valence. The real problem with the rivet method is mounting the trailing edge (rear) bracket that uses the rocker cover bolt. You can't access the bolt to secure the bracket to the rocker cover as it's behind the liner. So with my method you mount the bare bracket first and then fasten the liner to the bracket. Here's a better view of the finished product. No way you're getting your hand in behind the liner to tighten or loosen the bracket with the liner in place. With the speed nut and hex head screws I used, you can easily take the liner off in a matter of minutes without removing the brackets at the valance and rocker panel. Inspection and cleaning is still an easy thing to accomplish. I am making my own this week.. I have yet to figure out how I will affix everything but I like your thinking. |
raynekat 914Rubber fender liner installation Jan 31 2021, 05:48 PM
bkrantz Nice work, Doug. And very helpful--I have the lin... Jan 31 2021, 07:42 PM
FlacaProductions Good work - I have these awaiting install and I... Jan 31 2021, 08:54 PM
914e @raynekat Where did you get the hardware from? an... Feb 1 2021, 03:46 PM
raynekat
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 2 2021, 02:10 AM
mb911 And could you measure the bracket for me please? I... Feb 1 2021, 03:47 PM
raynekat
And could you measure the bracket for me please? ... Feb 2 2021, 02:12 AM
raynekat Finished up the passenger side of the front fender... Feb 2 2021, 02:18 AM
raynekat Finished out the rear fender wells today with the ... Feb 2 2021, 09:34 PM
raynekat Same drill for the rear or trailing edge of the li... Feb 2 2021, 09:35 PM
raynekat View of the front part of the liner bolted into th... Feb 2 2021, 09:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:52 AM |
