| JamesJ |
Feb 1 2021, 10:57 PM
Member ![]() ![]() Group: Members Posts: 272 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
Hello All,
Has anyone used these "GT door handle pull straps" from Auto Atlanta? I removed the armrest/compartment assemblies as I wanted a clean and simple look on this car. I bought a set of the these and prior to installing them(still figuring out the best way to do that), I rotated the handle that pivots on the mounting tabs back and forth. They only freely pivot about 45 degrees, then they fight you, but perhaps once mounted they will pivot more fully or maybe they are not meant to pivot a full 90 degrees. I "bench tested" them by just pressing the mounting tabs against a flat surface and I found that the 45 degree position is enough to get 3 or 4 fingers behind it to pull on it. The other issue is that they don't pivot back into the flat resting position because they are not spring loaded, so it appears that they will always be in the "open" position(see 2nd photo) and not sit against the door panel when not in use(I think I am ok with that); however, I am reluctant to put holes in my new door panels without knowing these will function well. I wish they were more sturdy than they are, but perhaps I am expecting too much from a $23 part. Could anyone share how these have worked for them or if there is another similar alternative? Perhaps from a 911/912 application or other European car model? Thanks! |
| live free & drive |
Feb 3 2021, 05:02 PM
Member ![]() ![]() Group: Members Posts: 212 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None
For slightly more panache - but essentially the same thing - the Alfa Spider driver's door pull:
https://www.ebay.com/itm/CLASSIC-ALFA-ROMEO...L4AAOSw9uFW-UK- |
JamesJ 914 GT Door Handle Pull Straps Feb 1 2021, 10:57 PM
john77 I have similar ones in my 914 - they were in the c... Feb 2 2021, 12:46 AM
JamesJ
I have similar ones in my 914 - they were in the ... Feb 2 2021, 12:50 AM
mepstein There are a couple sellers for the plastic ones on... Feb 2 2021, 07:10 AM
JamesJ
There are a couple sellers for the plastic ones o... Feb 2 2021, 08:17 AM
[quote name='mepstein' post='2887683' date='Feb 2... Feb 2 2021, 09:52 AM
Retroracer @JamesJ - I found mine from searching for "F... Feb 2 2021, 09:41 AM
mb911 I bought the fiat 500 handles for mine and they ar... Feb 2 2021, 10:27 AM
gms The handles you bought are copies of the FIAT 500 ... Feb 2 2021, 07:37 PM
mb911 Fyi for those interested.
https://www.ebay.com/i... Feb 2 2021, 07:55 PM
JamesJ I appreciate all the great feedback!
I see t... Feb 2 2021, 09:06 PM
raynekat The ONLY problem with the plastic ones is they can... Feb 2 2021, 10:04 PM
wysri9 Mine came from a UK Car Parts Supplier and are pla... Feb 3 2021, 05:24 AM
TRS63 Clean and nice solution! Feb 3 2021, 06:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:42 PM |
