Big 914 that will not idle, Idle Issue |
joeannwh8 |
Aug 22 2019, 03:40 PM
Newbie Group: Members Posts: 8 Joined: 22-August 19 From: Santa Clarita Member No.: 23,398 Region Association: Southern California |
I have a 72 914 that I have been working on forever, started a rebuild 15 years ago. A local machinist help me out and somehow the engine that I thought was a little bigger then 2.1L, I now calculate the size at 2366 cc (103mm x 71mm)! It has an electronic vacuum advance distributor and Solex H32/34 PD513 carbs, compression is 150 psi plus or minus 2 psi all around. Engine starts instantly warm or cold, rev's sluggishly but will quickly get to 6000 rpm easily. The issue is it will not idle below 2200 rpm.
What have I missed? |
joeannwh8 |
Sep 19 2019, 12:40 PM
Ok now it will idle some what, went through the timing thing again and it now lopes at around 900 rpm. Under load it will not go above 4500rpm. Air Cooled thinks I need 44's with no head work do I really need 44 or would 40's work?
I have a new issue though, the brakes don't stop the car as well as I remember, in the last 2 years I rebuilt all (4) calipers, cleaned out the proportional valve replaced the master cylinder, replaced the rear disks and replaced the pads. Pedal feels pretty solid. Any thoughts? |
jhynesrockmtn |
Feb 10 2021, 08:09 AM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
Ok now it will idle some what, went through the timing thing again and it now lopes at around 900 rpm. Under load it will not go above 4500rpm. Air Cooled thinks I need 44's with no head work do I really need 44 or would 40's work? I have a new issue though, the brakes don't stop the car as well as I remember, in the last 2 years I rebuilt all (4) calipers, cleaned out the proportional valve replaced the master cylinder, replaced the rear disks and replaced the pads. Pedal feels pretty solid. Any thoughts? If the soft lines have not been replaced I would do that. I renewed the braking system on a 1970 I bought last summer. The soft lines looked ok from the outside. The rears were literally plugged up 100%. The car had sat unused for long periods of time. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:06 AM |
