| john77 |
Feb 13 2021, 01:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California
While I have the arches cut for the flares I figured it was a good time to strip the wheel wells to bare metal, fix anything I find, and reseal them. I’ve completed the fronts, but just started stripping the rears yesterday and have some questions.
What’s the best way to reseal/rustproof the section above the rear light housing? I’ve stripped a lot of 1970’s German rubberized seam sealer in my time but was surprises to find that section was filled with what looks like some kind of expanding foam. The area is obviously a crud catcher, so I’m wondering the best way to seal it back up? Seam sealer? Or is there some other product I should fill the void where the foam was first? https://photos.app.goo.gl/2RYXDYXEVmRorirE9 The other section I’m wondering about is in the front of the well where the sail panel meets the quarter panel (the L shaped section coming down into the wheel well). It seems odd that this was so open - is it supposed to be covered in seam sealer? I’ve scraped some debris out of it, but would love some advice on what to do with it when I paint/reseal everything. https://photos.app.goo.gl/K2gqHAMPtzvMgiMB7 |
| raynekat |
Feb 13 2021, 10:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
On my restoration/build, we dug all that foam out of the rear corners.
The entire underside of my car is coated in body color Raptor bed liner....including the fender wells and where that foam was sitting. This Raptor is like granite, so should really hold up to debris and moisture. On top of that, I just finished installing fender liners that are easily removable....couple minutes for each. http://www.914world.com/bbs2/index.php?sho...amp;hl=raynekat I used hex headed screws instead of the supplied rivets for easy removal. When you need to inspect, it's a snap. |
| bbrock |
Feb 13 2021, 11:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
On my restoration/build, we dug all that foam out of the rear corners. The entire underside of my car is coated in body color Raptor bed liner....including the fender wells and where that foam was sitting. This Raptor is like granite, so should really hold up to debris and moisture. I did the same. Forgot to mention that but I made sure I shot a good build up into that area. I do think the metal is pretty well protected between the epoxy and Raptor but still don't want it to fill with crap that can trap water. |
john77 Rust proofing rear wheel wells Feb 13 2021, 01:10 PM
Cairo94507 I would clean out all of that foam filler junk and... Feb 13 2021, 01:27 PM
john77
I would clean out all of that foam filler junk an... Feb 13 2021, 01:46 PM
Cairo94507 Can you post a picture the area you are referencin... Feb 13 2021, 03:35 PM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Feb 14 2021, 02:20 AM
bbrock I've been mulling what to do with that area fo... Feb 13 2021, 03:38 PM
john77 I have nothing against what the factory did, it se... Feb 13 2021, 04:10 PM
bbrock
I have nothing against what the factory did, it s... Feb 13 2021, 08:25 PM
Jamie
I have nothing against what the factory did, it ... Feb 13 2021, 08:40 PM
bbrock
[quote name='bbrock' post='2891117' date='Feb 13 ... Feb 13 2021, 08:49 PM
john77 It just dawned on me that maybe I could use cavity... Feb 14 2021, 02:24 AM
mlindner On mine John, lots of cleaning, some painting and ... Feb 13 2021, 04:36 PM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Feb 14 2021, 02:26 AM
burton73 What do you think of fender liners?
My 86 928 has... Feb 13 2021, 07:08 PM
bkrantz I dug out all the original foam on both sides from... Feb 13 2021, 08:34 PM
bkrantz
On my restoration/build, we dug all that foam out... Apr 18 2021, 08:59 PM
Cairo94507 @john77 - I would seal that up the best way you c... Feb 14 2021, 08:50 AM
bbrock
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 14 2021, 12:25 PM
john77 Thanks Brent.
I ordered some raptor spray-on bedl... Feb 15 2021, 10:49 AM
mate914 I removed all seam sealer and foam. Then coal blas... Feb 14 2021, 09:05 AM
Geezer914 I second the use of bed liner. I undercoated the ... Feb 14 2021, 09:07 AM
930cabman I plan on removing the asphalt based undercoating ... Feb 14 2021, 04:30 PM
mlindner Sorry John missed your question. Its Polyethene ro... Apr 18 2021, 07:14 AM
john77 Thanks @[url=http://www.914world.com/bbs2/index.p... Apr 19 2021, 02:31 PM
Mikey914 We actually make these as a kit. Utilizing HDPE as... Apr 18 2021, 07:37 AM
mb911 I made my own liners and happy with them so far. Apr 19 2021, 06:41 AM
mlindner John77, if you'd like I can send you a paper t... Apr 20 2021, 04:18 AM
john77 That would be super helpful, thanks Mark!
Jo... Apr 20 2021, 12:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
