P-A Dealership repair times |
JeffBowlsby |
Feb 15 2021, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have this cool P-A dealership book from 1973 that indicates suggested repair times aimed primarily at dealership repairs and warranty work. Covers every assembly on the car. This would be a great resource for you guys who wrench on 914s for a living. Was reviewing this today and noted the following times in minutes for the 914/4 (it also indicates times for the 914/6):
360 Remove and reinstall engine and transaxle (incl disconnect/reconnect wiring, control cables, hoses, drive shafts, disconnect/reconnect transaxle from/to engine, check/adjust dwell, timing and idle. 30 Check complete fuel injection (uses VW tester and includes ECU R/R) 70 R/R all four injectors 240 Replace alternator (with engine installed) 220 R/R transaxle (with engine installed, incl. R/R muffler I am pretty sure I can beat at least some of their times, how about you? Whats your guess on how long it says it takes to replace the main wiring? (chassis harness) (IMG:style_emoticons/default/w00t2.gif) Attached thumbnail(s) |
fixer34 |
Feb 15 2021, 09:20 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I would like to know the time to adjust valves in a factory -6. Did that include 'cooling off' time since they weren't supposed to be done hot.
Think that goes for the -4's also. |
JeffBowlsby |
Feb 15 2021, 09:30 PM
Lo-Fi Version | Time is now: 9th June 2024 - 10:52 AM |
