P-A Dealership repair times |
JeffBowlsby |
Feb 15 2021, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have this cool P-A dealership book from 1973 that indicates suggested repair times aimed primarily at dealership repairs and warranty work. Covers every assembly on the car. This would be a great resource for you guys who wrench on 914s for a living. Was reviewing this today and noted the following times in minutes for the 914/4 (it also indicates times for the 914/6):
360 Remove and reinstall engine and transaxle (incl disconnect/reconnect wiring, control cables, hoses, drive shafts, disconnect/reconnect transaxle from/to engine, check/adjust dwell, timing and idle. 30 Check complete fuel injection (uses VW tester and includes ECU R/R) 70 R/R all four injectors 240 Replace alternator (with engine installed) 220 R/R transaxle (with engine installed, incl. R/R muffler I am pretty sure I can beat at least some of their times, how about you? Whats your guess on how long it says it takes to replace the main wiring? (chassis harness) (IMG:style_emoticons/default/w00t2.gif) Attached thumbnail(s) |
ejm |
Feb 17 2021, 02:44 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Volkswagen/Porsche/Audi has always used “time units – tu” for suggested repair times. There are 100 time units in an hour. So 25tu is 15 minutes and 100tu is an hour. So 360 time units to R&R an engine is just over 3 ½ hours.
And no they didn't allow cool down time so you would pop the valve covers first thing once on the lift and do the valve adjust last. Hopefully there was enough other work on the ticket that the engine cooled. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:05 AM |
