P-A Dealership repair times |
JeffBowlsby |
Feb 15 2021, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have this cool P-A dealership book from 1973 that indicates suggested repair times aimed primarily at dealership repairs and warranty work. Covers every assembly on the car. This would be a great resource for you guys who wrench on 914s for a living. Was reviewing this today and noted the following times in minutes for the 914/4 (it also indicates times for the 914/6):
360 Remove and reinstall engine and transaxle (incl disconnect/reconnect wiring, control cables, hoses, drive shafts, disconnect/reconnect transaxle from/to engine, check/adjust dwell, timing and idle. 30 Check complete fuel injection (uses VW tester and includes ECU R/R) 70 R/R all four injectors 240 Replace alternator (with engine installed) 220 R/R transaxle (with engine installed, incl. R/R muffler I am pretty sure I can beat at least some of their times, how about you? Whats your guess on how long it says it takes to replace the main wiring? (chassis harness) (IMG:style_emoticons/default/w00t2.gif) Attached thumbnail(s) |
JeffBowlsby |
Feb 17 2021, 04:16 PM
There is no indication in this book of what units the stated times are in. I don't doubt you Ed, it just seems like an odd way to measure time. The entire world is on the 60-minute hour, 24 hours/day standard. Using tu:
1.2 hrs for a /4 valve adjust seems tight, even Clay P would be challenged to do it that fast. 1200 tu for a chassis harness swap is 12 hours. Its a rarely done procedure so its hard to verify. 0.3 hrs to check the fuel injection even with the tester seems unlikely. I have the tester and know how to use it. 18 minutes would be nearly impossible with all that is involved. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:50 AM |
