| 930cabman |
Feb 20 2021, 07:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,872 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
We are attempting fitting a 2.7 into our 1974 rustout hulk but have come across another hurtle. I have had a 2.7 kicking around for awhile and "assumed" we could go through it with new bearings/rings/..... and have a nice power plant. Not so quick there. The head stud issue is well known and I recently found when the magnesium cases are disassembled the crankshaft bores no longer return to a round/aligned condition.
I want to believe someone out there can get these magnesium cases in serviceable condition with good crank bores and good head stud bores. thanks |
| gereed75 |
Feb 20 2021, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,456 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
There are several places that do this. Ollie’s and competition engineering are two old standbys. They have relatively long lead times - 8 weeks or so. Contact them for details
Also prepare for $ - figure $2500 at least There are some alternative places. You are in the Northeast. I have heard of a few places that do it, but do not have details. Hopefully someone else will chime in. Suggest you post to Pelican engine rebuild forum. There are a lot more knowledgeable people listening on that board. If you are doing heads, I recommend Craig Garret. 616-818-6629 He list often on Pelican. Also Anchor. https://anchoratlantic.com/ not sure either does case work Just saw that you posted over on Pelican. Do not know the details of your head stud issues. Check out “homebuilt by Jeff” on YouTube. He went through a complete case salvage with major spigot bore issues using a really competent rebuild shop in LA. Assume large coin. you can pick up these case for fairly cheap if yours can’t be fixed (they will still need machined). Karl Hens down at Thoroughbred Racing in Corry PA has a shitload of them. He also rebuilds a lot of motors. He can answer any questions about machinists also. |
930cabman 2.7 case guru Feb 20 2021, 07:41 AM
Luke M
We are attempting fitting a 2.7 into our 1974 rus... Feb 20 2021, 08:17 AM
mate914 Your close to a lot of engine builders. Karl Hens ... Feb 20 2021, 09:06 AM
brant The machine work on a mag case adds 3k to the rebu... Feb 20 2021, 09:06 AM
930cabman
The machine work on a mag case adds 3k to the reb... Feb 20 2021, 01:38 PM
Superhawk996
Exactly, why would we invest in a magnesium case... Feb 20 2021, 02:10 PM
The machine work on a mag case adds 3k to the re... Feb 20 2021, 03:30 PM
horizontally-opposed
For me, once you add in the durability, power, f... Feb 21 2021, 02:28 PM
mepstein Yea, unfortunately that’s the truth. Especially ... Feb 20 2021, 09:29 AM
Superhawk996 Had all my 2.4L case work done by Ollies.
All p... Feb 20 2021, 10:30 AM
mb911
All ... Feb 20 2021, 10:46 AM
sixnotfour Has to be torqued together with the nose bearing... Feb 20 2021, 12:06 PM
sixnotfour I have a small main bearing 3.0 case 6k..... Care... Feb 20 2021, 03:25 PM
914forme You can always find another 2.2, 2.4, and 2.7L fro... Feb 20 2021, 04:22 PM
930cabman
You can always find another 2.2, 2.4, and 2.7L fr... Feb 20 2021, 05:11 PM
gereed75 Sorry that you had bad luck with the first and sec... Feb 20 2021, 08:52 PM
davehg My Ollie’s bill was closer to $4k for my 2.... Feb 20 2021, 10:12 PM
sixnotfour numbers matching Feb 21 2021, 12:16 AM
rick 918-S
numbers matching
Wow that's cool! Feb 21 2021, 06:14 AM
930cabman
numbers matching
I suppose it's true, ... Feb 21 2021, 08:28 AM
numbers matching
I suppose it's true, ... Feb 21 2021, 08:56 AM
930cabman
[quote name='930cabman' post='2893282' date='Feb ... Feb 21 2021, 03:01 PM
Mark Henry
numbers matching
I suppose it's true, ... Feb 21 2021, 11:33 AM
Superhawk996 In the grand scheme of maching up mag cases, ... Feb 21 2021, 11:44 AM
jd74914
In the grand scheme of maching up mag cases, ... Feb 22 2021, 01:29 PM
In the grand scheme of maching up mag cases, ... Feb 22 2021, 02:13 PM
sixnotfour 2.4 mag ,,best engine ever.. Next week .I'll b... Feb 21 2021, 12:26 PM
sixnotfour 12,500
https://noonanrace.com/products/911-porsche... Feb 21 2021, 02:38 PM
12,500
https://noonanrace.com/products/911-porsch... Feb 21 2021, 03:07 PM
stownsen914 Pretty sure that ITG small bore case pictured abov... Feb 22 2021, 11:32 AM
bahnzai Cabman,
I have a ‘67 sand cast aluminum case eng... Feb 23 2021, 03:53 AM
930cabman Spend an hour or building a shipping crate to send... Mar 1 2021, 04:57 PM
Superhawk996
Spend an hour or building a shipping crate to sen... Mar 1 2021, 06:00 PM
930cabman Ollies contacted me last week, they are back logge... May 16 2021, 06:05 PM
rgalla9146 Could you keep us posted on turn-around and itemis... May 17 2021, 04:32 AM
930cabman
Could you keep us posted on turn-around and itemi... May 17 2021, 05:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th October 2026 - 12:03 PM |
