| flmont |
Feb 20 2021, 10:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh.
| tygaboy |
Feb 21 2021, 09:19 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,862 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Couldn't you slice the snorkel off the side of that air box and modify it (or make something else) so it comes out the top then heads rearwards and lives under the engine lid grill? It'd put your intake in a better place to pick up cold air.
Just my $.02,but if you can cut up your bulkhead, I'm betting you'd be able to fab up something that solves this issue. There are also these cobra head elbows that could maybe help? https://www.intakehoses.com/cobra-head-elbows.html Attached thumbnail(s) |
flmont I guess Iam cutting it... Feb 20 2021, 10:43 PM
rick 918-S I would try to move it back first. :ttiwwp: more p... Feb 21 2021, 05:32 AM
Superhawk996 I think I see the problem. . . . wrong engine in t... Feb 21 2021, 09:17 AM
76-914 Frank, I sent you a PM. Kent Feb 21 2021, 09:43 AM
mgp4591
I cant find a smaller Air intake,So I cant instal... Feb 21 2021, 10:53 AM
Chris914n6 2 180* mandrel bends or silicone hoses and relocat... Feb 21 2021, 12:49 PM
Literati914 :popcorn:
I have the same engine (though it needs... Feb 21 2021, 02:58 PM
mgp4591
:popcorn:
I have the same engine (though it need... Feb 21 2021, 03:13 PM
914forme If you have to cut it to make it work, flip it to ... Feb 21 2021, 04:59 PM
ClayPerrine You could always take the manifold off and machine... Feb 21 2021, 06:32 PM
flmont Tygaboy..Iam trying to post a Pic of my inlet tube... Feb 22 2021, 10:16 AM
Chris H. I'm running mine flipped the other way. It... Feb 22 2021, 03:43 PM
914forme
Here's a pic of a really cool custom intake.... Feb 22 2021, 07:31 PM
flmont Thanks Chris H....I thought about doing that then ... Feb 22 2021, 05:05 PM
Chris H.
Thanks Chris H....I thought about doing that then... Feb 22 2021, 07:08 PM
flmont and yes Clay maybe I could get a little bit more i... Feb 22 2021, 05:07 PM
flmont Literati914...what parts are you missing ? Feb 22 2021, 05:48 PM
Chris H. Yeah the main pipe would need to be fatter but the... Feb 22 2021, 08:09 PM
Literati914
Well... Feb 23 2021, 12:19 AM
Chris914n6 Happened to have the wheel off and thought of you.... Feb 24 2021, 02:24 PM
flmont Well,Thank You,!! How long has that been... Feb 27 2021, 12:17 PM
Chris914n6 ^^ 20 years and stock axles. And 200hp :)
If you ... Feb 27 2021, 08:27 PM
flmont WOW..and never a issue with them .Thats Great to k... Feb 27 2021, 11:55 PM
flmont Iam trying to load a pic of my new intake that I h... Oct 9 2021, 11:30 AM
Iam trying to load a pic of my new intake that I ... Oct 9 2021, 11:43 AM
flmont ok.Thank You,.! Frank Oct 9 2021, 02:07 PM
flmont RE: I guess Iam cutting it... Oct 9 2021, 05:39 PM
flmont this is the new intake, smaller than stk but not b... Oct 9 2021, 05:57 PM
flmont
This solves a lot of issues if it works as in... Oct 9 2021, 09:17 PM
Chris H. That’ll work great Frank. Is that from Rocky Mou... Oct 10 2021, 04:04 PM
flmont Yes,.. it is from Rocky Mtn westy,.I check that si... Oct 10 2021, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 04:03 AM |
