| flmont |
Feb 20 2021, 10:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh.
| ClayPerrine |
Feb 21 2021, 06:32 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
You could always take the manifold off and machine off a little bit of the throttle body mounting flange. From the looks of it in that picture, that would give you the clearance you need.
Clay |
flmont I guess Iam cutting it... Feb 20 2021, 10:43 PM
rick 918-S I would try to move it back first. :ttiwwp: more p... Feb 21 2021, 05:32 AM
Superhawk996 I think I see the problem. . . . wrong engine in t... Feb 21 2021, 09:17 AM
tygaboy Couldn't you slice the snorkel off the side of... Feb 21 2021, 09:19 AM
76-914 Frank, I sent you a PM. Kent Feb 21 2021, 09:43 AM
mgp4591
I cant find a smaller Air intake,So I cant instal... Feb 21 2021, 10:53 AM
Chris914n6 2 180* mandrel bends or silicone hoses and relocat... Feb 21 2021, 12:49 PM
Literati914 :popcorn:
I have the same engine (though it needs... Feb 21 2021, 02:58 PM
mgp4591
:popcorn:
I have the same engine (though it need... Feb 21 2021, 03:13 PM
914forme If you have to cut it to make it work, flip it to ... Feb 21 2021, 04:59 PM
flmont Tygaboy..Iam trying to post a Pic of my inlet tube... Feb 22 2021, 10:16 AM
Chris H. I'm running mine flipped the other way. It... Feb 22 2021, 03:43 PM
914forme
Here's a pic of a really cool custom intake.... Feb 22 2021, 07:31 PM
flmont Thanks Chris H....I thought about doing that then ... Feb 22 2021, 05:05 PM
Chris H.
Thanks Chris H....I thought about doing that then... Feb 22 2021, 07:08 PM
flmont and yes Clay maybe I could get a little bit more i... Feb 22 2021, 05:07 PM
flmont Literati914...what parts are you missing ? Feb 22 2021, 05:48 PM
Chris H. Yeah the main pipe would need to be fatter but the... Feb 22 2021, 08:09 PM
Literati914
Well... Feb 23 2021, 12:19 AM
Chris914n6 Happened to have the wheel off and thought of you.... Feb 24 2021, 02:24 PM
flmont Well,Thank You,!! How long has that been... Feb 27 2021, 12:17 PM
Chris914n6 ^^ 20 years and stock axles. And 200hp :)
If you ... Feb 27 2021, 08:27 PM
flmont WOW..and never a issue with them .Thats Great to k... Feb 27 2021, 11:55 PM
flmont Iam trying to load a pic of my new intake that I h... Oct 9 2021, 11:30 AM
Iam trying to load a pic of my new intake that I ... Oct 9 2021, 11:43 AM
flmont ok.Thank You,.! Frank Oct 9 2021, 02:07 PM
flmont RE: I guess Iam cutting it... Oct 9 2021, 05:39 PM
flmont this is the new intake, smaller than stk but not b... Oct 9 2021, 05:57 PM
flmont
This solves a lot of issues if it works as in... Oct 9 2021, 09:17 PM
Chris H. That’ll work great Frank. Is that from Rocky Mou... Oct 10 2021, 04:04 PM
flmont Yes,.. it is from Rocky Mtn westy,.I check that si... Oct 10 2021, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 04:03 AM |
