Problem solved! Emergencyish Situation! Need a good MPS, MPS failure right before shipping car. |
hcdmueller |
Feb 20 2021, 06:55 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I am in the middle of moving to the UK. The Air Force has already picked up all of our stuff. 2 days ago I tried to start my car and no luck. It's a 76 and after relacing or troubleshooting everything, it's still not starting. I bit the bullet and bought a vacuum pump from Harbor Freight to check out the MPS. It isn't a complete fail, but it leaks down from 20 to 14 lbs in < 4 min.
List if things I've done. New vacuum lines, rubber intake sleeves, injector seals, fuel filter, spark plugs, head temp sensor. Checked fuel pressure, injector function, TPS adjustment. I have the 123ignition distributor with new cap and rotor. I have to ship this car in 10 days or less. Obviously it needs to be running. Does anyone have a known good 2.0 compatible MPS I could borrow/rent/purchase right now? I'm in Panama City, FL. Given the weather, something closer to me would probably be better. Other options could be a good running set of carbs and intakes or if someone has a plug n play microsquirt setup sitting on the shelf. Any help is appreciated. |
hcdmueller |
Feb 21 2021, 09:10 PM
So, the problem has been solved.
After checking all the obvious stuff, out of desperation, I pulled the intake manifold and runners to check for any sort of leaks. The paper gaskets on the phenolic spacers had been sucked in toward the head causing a huge vacuum leak. As far as I can tell, the cold weather was actually the problem. This car has only been run in temps over 65deg for the past 8ish years. First Arizona and now Florida. The day it decided not to start, the temp outside was below freezing. I guess everything loosened up just enough in the cold. I just finished bolting everything back together and it fired up after a couple tries. I appreciate all the questions, feedback, etc. It definitely reminded me to check everything more than once. I guess I'll have to build a new engine, this one's been in for over a decade and is starting to act up. Time to go big. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:22 PM |
