Trim sealant, What is being used? |
Morph914 |
Feb 21 2021, 08:05 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
wonkipop |
Feb 22 2021, 04:10 AM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
sikaflex is a butyl based sealant.
been widely used in the building industry for half a century. stays flexible for a long time as it skins over only on surface exposed to air. is black. sticks like (IMG:style_emoticons/default/stromberg.gif) to a blanket. i'm guessing that is what stuff still on trims might be. there is also another sealant that was used in the 70s for glazing in buildings. even today when you pull 70s glazing apart it is still flexible, sticky and liquid almost. its got a name? and i think it is referred to as mastik these days. but it did have a different name back then. it doesn't cure over time and go hard like modern silicone based sealants. its real messy stuff. sikaflex can also be pretty messy if you are not careful. though usually you can use water to wipe it clean. usually applied using a glove with a bucket of water (with a tiny bit of detergent mixed) beside you to finger work it then sort of wipe it clean. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:40 PM |
