> seat options with better support and the taller driver, what have those drivers 6 foot plus found? I want a head rest that actually behind not below my head!
DRPHIL914
post Feb 23 2021, 07:39 AM
Dr. Phil
first off- i am 6'1", the primary use of this seat will be for AX and trips to the mountains, aggressive driving. I want better side support and head protection. right now if i got hit from behind like Clay did my head would be shattering the rear window, so this is not a good scenario.
i've been searching forum here looking at what others have used. I have looked at the seats that Stefan at GTS Classics makes, and as i look at those options, it seems the best fit and option might be the one that has a 914 shaped headrest but can be raised and lowered, i think it s the Nurburgring, but recently saw a set a member had made i think were the Watkins Glen, they seem to fit in a 914 nicely but the headrest is fixed in place and does not appear to be taller than stock,
So i am looking for options that wont completely break the bank but give great support and fit better for my height and size. I did buy some Corbeau from a member but found they are made for someone 5'8" or smaller and as thin as i am, even narrower. so those are gone and i am researching this time better before i buy.
Please post pics if you have them!!!
PCH
post Feb 23 2021, 12:18 PM
6'2" (and shrinking) here. I've had two different stock seat sets in my car and found both very comfortable.
My biggest problem was getting my legs under the steering wheel with the top on. A little smaller in diameter wood Nardi steering wheel took care of that problem. But now the speedo and tach are partially covered by the wheel.
As an alternate, making a thinner bottom pad wouldn't be that difficult. Memory foam might be especially comfortable.
DRPHIL914   seat options with better support and the taller driver   Feb 23 2021, 07:39 AM
Steve   I'm 5'10" and my GTS Lemans seat goes...   Feb 23 2021, 09:22 AM
mepstein   Unless you are willing to pony up the money for cu...   Feb 23 2021, 09:38 AM
DRPHIL914   Unless you are willing to pony up the money for c...   Feb 23 2021, 09:47 AM
mepstein   Having track seats would also be easier on your go...   Feb 23 2021, 10:04 AM
horizontally-opposed   So many variables with seats—which is why the st...   Feb 23 2021, 10:41 AM
PCH   6'2" (and shrinking) here. I've had t...   Feb 23 2021, 12:18 PM
oakdalecurtis   6'2" (and shrinking) here. I've had ...   Feb 24 2021, 10:39 AM
Racer   One old trick when autocrossing? Remove seat bot...   Feb 23 2021, 01:03 PM
DRPHIL914   I bought a bag of them from SMC a while ago. If y...   Feb 24 2021, 08:19 AM
ClayPerrine   i think i do lean toward just a modified stock ...   Feb 24 2021, 08:23 AM
DRPHIL914   i think i do lean toward just a modified stock...   Feb 24 2021, 08:33 AM
horizontally-opposed   Phil, JWest Engineering makes a steering eccent...   Feb 24 2021, 08:37 AM
Craigers17   Dr. Phil, I have a pair of GTS Seats that might w...   Feb 24 2021, 08:48 AM
DRPHIL914   Dr. Phil, I have a pair of GTS Seats that might ...   Feb 24 2021, 09:08 AM
Craigers17   ....a few more pics......they are also a little du...   Feb 24 2021, 08:53 AM
horizontally-opposed   ^ This is really appealing. The factory 914 seat...   Feb 24 2021, 08:59 AM
Luke M   Have you looked at the Recaro pole position seats?...   Feb 24 2021, 09:51 AM
DRPHIL914   Have you looked at the Recaro pole position seats...   Feb 24 2021, 12:41 PM
Luke M   [quote name='Luke M' post='2894237' date='Feb 24 ...   Feb 24 2021, 12:49 PM
eric9144   Have you looked at the Recaro pole position seats...   Feb 24 2021, 10:54 AM
DRPHIL914   [quote name='Luke M' post='2894237' date='Feb 24 ...   Feb 24 2021, 12:58 PM
DRPHIL914   Have you looked at the Recaro pole position seat...   Feb 25 2021, 11:43 AM
Mark Henry   I didn't read all of this but I did the thinne...   Feb 24 2021, 02:07 PM
eric9144   @Luke M no back pad at the moment, maybe someday ...   Feb 24 2021, 05:13 PM
eric9144   are these Recaro Pole position seats? did you get...   Feb 25 2021, 11:56 AM
DRPHIL914   are these Recaro Pole position seats? did you ge...   Feb 25 2021, 12:10 PM
- Lo-Fi Version Time is now: 18th November 2026 - 04:06 PM
