| Tdskip |
Feb 10 2021, 01:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
The 1975 is not recharging the battery, so I obviously have either a fault with the alternator or the wiring/charging circuit.
In the interest of being just slightly less of a dope than I currently am, what would cause the charging circuit to fail if it is not an internal alternator issue. In other words, if we assume that the alternator is healthy and there’s no issues with the brushes etc. internal to the alternator wear with the wiring I have gone sideways to result in it not charging? This seems like a useful topic to get into the forum here, thanks in advance for the shared knowledge. |
| rick 918-S |
Feb 23 2021, 12:26 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,279 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Possibly a bad relay board. Clays test may rule this out too.
Tdskip Drop some knowledge: what external faults would prevent an alternator from charging? Feb 10 2021, 01:10 PM
Jonathan Livesay
The 1975 is not recharging the battery, so I obvi... Feb 10 2021, 01:16 PM
ClayPerrine Do a full field test on the alternator.
With the ... Feb 10 2021, 01:29 PM
VaccaRabite Grounds. Check them. Clean them.
Even a small gr... Feb 10 2021, 02:45 PM
Mikey914 Also, if your bulb for the alternator doesn't ... Feb 10 2021, 03:06 PM
flyer86d
Also, if your bulb for the alternator doesn't... Feb 10 2021, 04:03 PM
Mikey914 Hopefully this is it. Feb 10 2021, 04:19 PM
Tdskip Thanks for all of the responses - the bulb works (... Feb 10 2021, 05:35 PM
Jonathan Livesay
Thanks for all of the responses - the bulb works ... Feb 10 2021, 07:59 PM
stickyfingers
Thanks for all of the responses - the bulb works... Feb 23 2021, 11:17 AM
ndfrigi
[quote name='Jonathan Livesay' post='2890148' dat... Feb 23 2021, 11:28 AM
Mark Henry
[quote name='Jonathan Livesay' post='2890148' dat... Feb 23 2021, 01:09 PM
Tdskip Highjack away if it helps, no worries.
My dash li... Feb 23 2021, 11:50 AM
Spoke You can do a rudimentary test on the alternator th... Feb 24 2021, 05:41 AM
rgalla9146 All great advise.
Do these basic checks as we... Feb 24 2021, 06:30 AM
mate914 I was going to say grounds... also.
How about a ... Feb 24 2021, 06:38 AM
Tdskip Hi folks – just wanted to close this out. Turns ... Mar 11 2021, 03:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 05:44 AM |
