| DRPHIL914 |
Feb 23 2021, 07:39 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
first off- i am 6'1", the primary use of this seat will be for AX and trips to the mountains, aggressive driving. I want better side support and head protection. right now if i got hit from behind like Clay did my head would be shattering the rear window, so this is not a good scenario. i've been searching forum here looking at what others have used. I have looked at the seats that Stefan at GTS Classics makes, and as i look at those options, it seems the best fit and option might be the one that has a 914 shaped headrest but can be raised and lowered, i think it s the Nurburgring, but recently saw a set a member had made i think were the Watkins Glen, they seem to fit in a 914 nicely but the headrest is fixed in place and does not appear to be taller than stock, So i am looking for options that wont completely break the bank but give great support and fit better for my height and size. I did buy some Corbeau from a member but found they are made for someone 5'8" or smaller and as thin as i am, even narrower. so those are gone and i am researching this time better before i buy. Please post pics if you have them!!! |
| Craigers17 |
Feb 24 2021, 08:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 916 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States
Dr. Phil,
I have a pair of GTS Seats that might work for you. They will probably address your side bolster issues, but likely NOT your headrest issue, as the headrests on these seats are actually probably even more shallow than stock, and not any taller. The seats are loosely based on GT racing seats and are made from 914 cores. If you have any future business in the Atlanta area, I would be glad to meet up and you could take a test fit if desired. They currently have no rails or sliders, so it still wouldn't be as good as a test actually mounted in the 914. One seat does have a very small tear/cut in the back that I assume happened during shipping. Let me know if you'd be interested in taking a look if your schedule/ travel plans permit. I have included several pics. |
| DRPHIL914 |
Feb 24 2021, 09:08 AM
Dr. Phil, I have a pair of GTS Seats that might work for you. They will probably address your side bolster issues, but likely NOT your headrest issue, as the headrests on these seats are actually probably even more shallow than stock, and not any taller. The seats are loosely based on GT racing seats and are made from 914 cores. If you have any future business in the Atlanta area, I would be glad to meet up and you could take a test fit if desired. They currently have no rails or sliders, so it still wouldn't be as good as a test actually mounted in the 914. One seat does have a very small tear/cut in the back that I assume happened during shipping. Let me know if you'd be interested in taking a look if your schedule/ travel plans permit. I have included several pics. @Craigers17 I am interested, might have to try and work something out schedule wise. those are pretty deep but would certainly give super support. i will PM you to get some more info. as far as height and headrest goes, i still could lower the cushion by removing some foam or taking the cusion out completely for the day. ---- Phil |
DRPHIL914 seat options with better support and the taller driver Feb 23 2021, 07:39 AM
Steve I'm 5'10" and my GTS Lemans seat goes... Feb 23 2021, 09:22 AM
mepstein Unless you are willing to pony up the money for cu... Feb 23 2021, 09:38 AM
DRPHIL914
Unless you are willing to pony up the money for c... Feb 23 2021, 09:47 AM
mepstein Having track seats would also be easier on your go... Feb 23 2021, 10:04 AM
horizontally-opposed So many variables with seats—which is why the st... Feb 23 2021, 10:41 AM
PCH 6'2" (and shrinking) here. I've had t... Feb 23 2021, 12:18 PM
oakdalecurtis
6'2" (and shrinking) here. I've had ... Feb 24 2021, 10:39 AM
Racer One old trick when autocrossing?
Remove seat bot... Feb 23 2021, 01:03 PM
DRPHIL914
I bought a bag of them from SMC a while ago. If y... Feb 24 2021, 08:19 AM
ClayPerrine
i think i do lean toward just a modified stock ... Feb 24 2021, 08:23 AM
DRPHIL914
i think i do lean toward just a modified stock... Feb 24 2021, 08:33 AM
Phil,
JWest Engineering makes a steering eccent... Feb 24 2021, 08:37 AM
Craigers17 ....a few more pics......they are also a little du... Feb 24 2021, 08:53 AM
horizontally-opposed ^ This is really appealing.
The factory 914 seat... Feb 24 2021, 08:59 AM
Luke M Have you looked at the Recaro pole position seats?... Feb 24 2021, 09:51 AM
DRPHIL914
Have you looked at the Recaro pole position seats... Feb 24 2021, 12:41 PM
Luke M
[quote name='Luke M' post='2894237' date='Feb 24 ... Feb 24 2021, 12:49 PM
eric9144
Have you looked at the Recaro pole position seats... Feb 24 2021, 10:54 AM
DRPHIL914
[quote name='Luke M' post='2894237' date='Feb 24 ... Feb 24 2021, 12:58 PM
DRPHIL914
Have you looked at the Recaro pole position seat... Feb 25 2021, 11:43 AM
Mark Henry I didn't read all of this but I did the thinne... Feb 24 2021, 02:07 PM
eric9144 @Luke M no back pad at the moment, maybe someday ... Feb 24 2021, 05:13 PM
eric9144
are these Recaro Pole position seats? did you get... Feb 25 2021, 11:56 AM
DRPHIL914
are these Recaro Pole position seats? did you ge... Feb 25 2021, 12:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 04:06 PM |
