Hoosier A7 tire size on flared car |
PlaysWithCars |
Feb 13 2021, 02:33 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I've been running 225/45R15 on 7" and 8" wheels and they worked fine. But now that I need new tires I'm going to 8s all the way around and debating about stepping up to 245/40R15. Anyone have experience with 245 on 8" wheel? It's within spec from Hoosier for that tire and through email correspondence with Hoosier they said it would work fine. I also asked them about building heat in the tire since I struggle with that on the 225s already. They said that yeah I would build less heat but the cooler 245s would generate more grip than slightly warmer 225s.
PlaysWithCars |
Mar 2 2021, 10:51 PM
Thanks for the heads up Chris. I noticed they were going to be tight in that area so I was able to do a slight trim and rounding of the corner to get good clearance.
Everything worked well and to my surprise, no rubs on the front and only a slight rub on the back between the tire and the inner fender well. I've added a 4mm spacer to the back and think that will be just about perfect. Except, now I need to put longer studs in the rear hubs as its not even flush with the top of the lug nut. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 06:10 PM |
