Brake fluid, What to use? |
EJP914 |
Mar 3 2021, 01:05 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I am in the process of replacing all of my brake calipers and hoses on '73 1.7 that has been sitting for about 15 years.. From notes that I got from the previous owner says he changed to silicone brake fluid (many years ago). Fluid in the reservoir is kind of purple in color so I'm guessing its DOT 5 type.
Before I start pulling this fluid thru the new calipers, any reasons why I shouldn't just stay with DOT 5 fluid? Any downside to using DOT 5 in these cars? Thanks for the comments EJP914 |
brant |
Mar 3 2021, 02:25 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
dot 4 and dot 5 do not mix
do not use dot 5 |
mgp4591 |
Mar 3 2021, 03:13 PM
914 Guru Group: Members Posts: 5,383 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
brant |
Mar 3 2021, 03:23 PM
dot 4 and dot 5 do not mix do not use dot 5 What fluid would you recommend to flush the system before refilling with DOT4? I just use the same new good fluid to flush with. it takes a little extra... but that way you know what the final boiling point will be rather than a mix |
Lo-Fi Version | Time is now: 9th June 2024 - 07:08 PM |
