Brake fluid, What to use? |
EJP914 |
Mar 3 2021, 01:05 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I am in the process of replacing all of my brake calipers and hoses on '73 1.7 that has been sitting for about 15 years.. From notes that I got from the previous owner says he changed to silicone brake fluid (many years ago). Fluid in the reservoir is kind of purple in color so I'm guessing its DOT 5 type.
Before I start pulling this fluid thru the new calipers, any reasons why I shouldn't just stay with DOT 5 fluid? Any downside to using DOT 5 in these cars? Thanks for the comments EJP914 |
GregAmy |
Mar 3 2021, 07:04 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The significant rating difference between DOT 3 and DOT 4 is the "wet" boiling point. DOT 4 is higher.
"Wet" boiling point is the temperature at which the fluid will boil when it has absorbed all the moisture it can. Which means every Hyundai, Civic, Camry out there today. DOT 4 actually absorbs moisture faster, so should be changed more often. If you flush it regularly* DOT 4 is perfectly fine. If you're street driving, never tracking, and you'l let it ride for 5+ years, DOT 3 may be a better option. I race on DOT 4 and change it a couple times a year. My street cars typically have DOT 3. *I think "every year" is a bit anal...but at least I know I'm safe around you. (IMG:style_emoticons/default/wink.gif) My wife is my pedal pusher too. I just noticed that Harbor Freight as a vacuum bleed system that runs on shop air, I'm tempted to give it a try. |
Root_Werks |
Mar 4 2021, 10:47 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The significant rating difference between DOT 3 and DOT 4 is the "wet" boiling point. DOT 4 is higher. "Wet" boiling point is the temperature at which the fluid will boil when it has absorbed all the moisture it can. Which means every Hyundai, Civic, Camry out there today. DOT 4 actually absorbs moisture faster, so should be changed more often. If you flush it regularly* DOT 4 is perfectly fine. If you're street driving, never tracking, and you'l let it ride for 5+ years, DOT 3 may be a better option. I race on DOT 4 and change it a couple times a year. My street cars typically have DOT 3. *I think "every year" is a bit anal...but at least I know I'm safe around you. (IMG:style_emoticons/default/wink.gif) My wife is my pedal pusher too. I just noticed that Harbor Freight as a vacuum bleed system that runs on shop air, I'm tempted to give it a try. Probably my lack of skill, but I always make such a mess when I use a pressure bleeder. Wound up getting rid of mine years ago. But again, probably me, not the pressure bleeders fault. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:00 PM |
