Brake fluid, What to use? |
EJP914 |
Mar 3 2021, 01:05 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I am in the process of replacing all of my brake calipers and hoses on '73 1.7 that has been sitting for about 15 years.. From notes that I got from the previous owner says he changed to silicone brake fluid (many years ago). Fluid in the reservoir is kind of purple in color so I'm guessing its DOT 5 type.
Before I start pulling this fluid thru the new calipers, any reasons why I shouldn't just stay with DOT 5 fluid? Any downside to using DOT 5 in these cars? Thanks for the comments EJP914 |
GregAmy |
Mar 3 2021, 07:04 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The significant rating difference between DOT 3 and DOT 4 is the "wet" boiling point. DOT 4 is higher.
"Wet" boiling point is the temperature at which the fluid will boil when it has absorbed all the moisture it can. Which means every Hyundai, Civic, Camry out there today. DOT 4 actually absorbs moisture faster, so should be changed more often. If you flush it regularly* DOT 4 is perfectly fine. If you're street driving, never tracking, and you'l let it ride for 5+ years, DOT 3 may be a better option. I race on DOT 4 and change it a couple times a year. My street cars typically have DOT 3. *I think "every year" is a bit anal...but at least I know I'm safe around you. (IMG:style_emoticons/default/wink.gif) My wife is my pedal pusher too. I just noticed that Harbor Freight as a vacuum bleed system that runs on shop air, I'm tempted to give it a try. |
Root_Werks |
Mar 4 2021, 10:47 AM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The significant rating difference between DOT 3 and DOT 4 is the "wet" boiling point. DOT 4 is higher. "Wet" boiling point is the temperature at which the fluid will boil when it has absorbed all the moisture it can. Which means every Hyundai, Civic, Camry out there today. DOT 4 actually absorbs moisture faster, so should be changed more often. If you flush it regularly* DOT 4 is perfectly fine. If you're street driving, never tracking, and you'l let it ride for 5+ years, DOT 3 may be a better option. I race on DOT 4 and change it a couple times a year. My street cars typically have DOT 3. *I think "every year" is a bit anal...but at least I know I'm safe around you. (IMG:style_emoticons/default/wink.gif) My wife is my pedal pusher too. I just noticed that Harbor Freight as a vacuum bleed system that runs on shop air, I'm tempted to give it a try. Probably my lack of skill, but I always make such a mess when I use a pressure bleeder. Wound up getting rid of mine years ago. But again, probably me, not the pressure bleeders fault. |
GregAmy |
Mar 4 2021, 11:15 AM
Probably my lack of skill, but I always make such a mess when I use a pressure bleeder. Wound up getting rid of mine years ago. But again, probably me, not the pressure bleeders fault. Me too, I never liked them. But this one is a vacuum bleeder, using shop air (I have a compressor). Recommended to me by a good buddy. At $90 it's worth a shot. https://www.harborfreight.com/merchandising...-kit-57057.html |
GregAmy |
Mar 4 2021, 06:54 PM
Me too, I never liked them. But this one is a vacuum bleeder, using shop air (I have a compressor). Recommended to me by a good buddy. At $90 it's worth a shot. Got one, tried it tonight. I made a mess. Granted, I didn't use it completely correctly, so I'll give it another shot later. But it does not like the very small nipples on the Wilwood Dynalite calipers. More in tune with larger stock ones. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:34 AM |
